Seat removal gotchas. (2006 E55)
But all I'm going to do is remove my right passenger seat and temporarily replace it with one I bought with the intent of turning it into and office chair only to be able to adjust it to a good sitting position (it shipped leaned way forward).
I haven't dug in yet but I'm guessing 4 main bolts and about 4-6 plugs.
Has ANYONE removed or replaced a seat?
Then apply 12V to the motors to get them to move in the desired direction. Of course, it could be that the only thing going to the seat is 12V and a CAN interface, but that would seem overly complex
Plan on removing the passenger seat (found a nice write-up) but I will also document it.
Gotta get the seat in and powered up so I can move it into a position for use. I don't plan on going the extensive route of adding a battery, the brains, and the additional seat controls (would be awesome...but just don't see it as reasonable).
But it should still make a cool office chair.
Gotta run out to get a star socket for those for bolts.
4 E-12 external Torx bolts hold the seat in and then there are 4 harnesses and one vacuum line and the side mounted seat belt.
Step 1: Move seat all the way back and take out the front two bolts
Step 2: Move seat forward enough to access the rear two bolts
Step 3: Remove all bolts and make sure seat is relatively centered
Step 4: Disconnect battery
Step 5: Lean seat backward (manually - duh...just lean it back on its rails)
Step 6: Disconnect all harnesses & vacuum line and then pop the wire loop that bundles the wires off the bottom of the seat
Step 7: Remove seat belt (internal torx)
Step 8: Remove seat
Very simple. I took some pics but since it's SO easy, there's really no point.
By disconnected the accessory battery (or whatever that is in the upper left hand corner of the engine bay) I did NOT get any sort of SRS warning.
Now I've just got to fab up the base to attach my chair base to and then bolt the seat to it and I've got my niffty E55 OFFICE CHAIR!
Would you throw a quick measure on your E55 seat base?
I have often wondered if I could squeeze E55 seats into the C32.
(Ignoring the electronics issue for the moment)
Hmmm...I can imagine one of these hunkin' seats in my C32...one of the things I loved about that car were how race like I thought the seat were. These are bloated in comparison. But I definitely could be wrong!
And yes...just disconnecting that "little battery" did the trick!!! Found that on Benzworld I think. The seat is actually "hot"...meaning you can move it via the controls while working.
On another note, I'm removing my drivers seat today to replace the seat belt buckle and harness. Good info cause I need to go buy a TORX socket set.
Glad I could help!
As far as an update on my seat removal, I did it today with no issues. I did end up having to run back and buy that other torx socket (I think it was an E-45 or so).
I was somewhat concerned because my SRS light was on before with the broken harness, and people said that the dealer would have to turn it off. I was happy when I turned the car back on after I was done and the SRS light went off on its own.
Hopefully, it's just an issue with loose connectors or a readjustment, but this DIY will help me tremendously.
thanks!
I'm glad to see there is DIY for certain things, but I do get frustrated with all the comments about 'see STAR, check online...' I thought that forums were created to help each other out...
