Sub draining the battery, shuts off..solutions?
Old Jan 13, 2011 | 04:52 PM
E55Dimon's Avatar
E63S
Just installed a JL Audio 12" W6 with a rockford 600.1 amp. All wired to the trunk battery. Now, it works for a bit but then I get the battery warning on the dash and it shuts off.
Is there a way around this, or do I just need a capacitor?
TIA
Old Jan 13, 2011 | 05:33 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
A 2nd battery would do the trick . I wonder if they make a Phoenix gold alternator for your car ????
Old Jan 13, 2011 | 05:45 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
I've got a heavier duty battery and a capacitor for the sub in my system...no problems with shutoff.
Jon
Old Jan 13, 2011 | 06:01 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
heavy duty batter and cap definately....
assume you removed the factory amp as well? Otherwise she will drain your battery as well. I had that when I changed out all the equipment. Had to disconnect it otherwise it draws constant power.
Old Jan 13, 2011 | 06:59 PM
E55Dimon's Avatar
E63S
Im wondering if just the capacitor will do the trick. Its just one sub, and I've ran much larger systems in my previous cars without issue. The rear battery looks a bit larger than usual too.
The situation sucks though, when the thing dies mid-song doesnt make me happy.
Old Jan 13, 2011 | 07:02 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Just try a 10 farad cap. I bet that will solve the problem.
Also is it the car that dies or just the amp that cuts off the subs or the whole sound system cuts out?
Old Jan 13, 2011 | 07:54 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
http://www.odysseyfactory.com/
Old Jan 13, 2011 | 07:58 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Systems in our fiber optic cars always have weird bugs. Just keep it stock and rock smooth jazz over your thunder machine.
Old Jan 13, 2011 | 08:00 PM
E55Dimon's Avatar
E63S
Car doesnt die, just throws the warning and shuts sub off. Just tried it again, didnt work at all. Sound works, but factory. Driving me nuts.
Going to throw a capacitor in, see it changes anything. What's upsetting is that its the smallest system I've ran, and I'm getting this bs.
Old Jan 13, 2011 | 08:05 PM
E55Dimon's Avatar
E63S
Lol
Old Jan 13, 2011 | 08:06 PM
harjothundal's Avatar
05 e55
the reason you are getting the warning in the dash is because you most likely have your amp power being supplied directly from the battery terminals... the electrical system in this car is very complex... there are 2 batteries, and in the middle is a battery control module... when your amp is pushing a heavy load, it is most likely making the voltage on the main battery dip below the warning threshold... when the bcm sees this, it thinks the batt is low, and the car will start to shut off consumers to reduce the load on your electrical system... the real "proper" way would be to wire your amps power from the sam, but that gets very complex as your aftermarket amp is going to want massive power...
it's a complex situation, and the only reason i haven't touched the stereo in my car...
Old Jan 13, 2011 | 08:18 PM
E55Dimon's Avatar
E63S
Didnt want to hear that, damn! Haha.
Old Jan 13, 2011 | 08:59 PM
skratch77's Avatar
2005 E55
Yup I had the same problem,hooked up a 500/1 jl mono amp and a 12w6 and after 10 min the car started shutting stuff off.
I was told to take power on the bat and try to ground somewhere on the car but I gave up since I could barely hear the sub anyway.
Old Jan 14, 2011 | 09:01 AM
izzyz28's Avatar
2004 E55 AMG
Ground the negative lead to anything but the battery terminal and you will never have another problem. I did the exact same thing as you and got the message constantly. As soon as I grounded the amp to the chassis the message never came back.
BTW, it looks like you've noticed that it takes a ridiculous amount of power to get much sound out of a sub in these cars. I have well over 1200W going to my sub and I still think it sucks.
Old Jan 14, 2011 | 09:03 AM
Roverron's Avatar
ML63
There is a work around with a diode on the battery monitor lead.
You are going to need a cap on those "hard hits" being high volume because the voltage drops so fast.
I have an old school kicker ZR 1000 on 2 15's. And that amp is a pig for power.
I think there is a post somewhere by a board sponsor the guys with the plug and play remote start. On this very issue.
Old Jan 14, 2011 | 11:40 AM
AMGfan's Avatar
I am not sure where the sub is in the OP car, but having the subs in the 55 mounted under my rear deck really alleviates the problem as far as bass transference into the cabin.
Jon
Old Jan 14, 2011 | 11:52 AM
abrim's Avatar
Viper SRT-10, 68 Camaro
Jon
Do you have any more pics of your audio setup? I am looking to do something very similar in mine.
Old Jan 14, 2011 | 02:28 PM
E55Dimon's Avatar
E63S
Thanks guys. Going to switch the ground and add a capacitor. Hope that will solve my problem.
Old Jan 19, 2011 | 02:32 PM
E55Dimon's Avatar
E63S
Just an update: It was a bad ground! All fixed and working now. And dang, now I understand what exactly you guys mean about how well insulated this car is. Now I see/am thinking about the AMGfan setup.
It sounds just perfect and awesome with hip-hop, but I'm more of a trance/house kinda guy and it lacks a bit there. Decisions.
Again, thank you everyone for your help!
Old Jan 19, 2011 | 02:55 PM
E55Dimon's Avatar
E63S
Couple pics:
Moved the sub to the right as I need the trunk space. (Only reason I went with one sub).
Aaand my small fav. mod the 5.5 badges
Old Jan 19, 2011 | 05:00 PM
jayhawkblk's Avatar
2012 Armada
The only cap of sorts I would use is a Bat Cap . Get a secondary battery. As for bass transfer I have my subs running IB through the rear deck. few photos.
Old Jan 19, 2011 | 05:21 PM
AMGfan's Avatar
jayhawkblk...that looks really clean brother!
Old Jan 19, 2011 | 05:26 PM
jayhawkblk's Avatar
2012 Armada
Thanks Mang. I try. I am actually getting ready to redo it again. The subs will stay the in the same configuration. But that B8 that you see in the photo its twin is under it and I want to show them both off. Plus there is a 4100 behind the AMG sign.
Old Jan 19, 2011 | 06:10 PM
Busta Riles's Avatar
1969 280S, 1991 300E
Interesting...i've been having the same problem with my car.
Every once in a while, the sub will fire without the music being turned on as well.
It's been bugging me, but it's also minus 40 outside, so not like i'm cruising around all the time.
Old Jan 19, 2011 | 06:11 PM
Jon
Where do you get a heavier duty battery than the big Benz one? Do you have a model number?
