180mm Pulley and Tune dyno results, what do these numbers mean??
Old Jan 20, 2011 | 02:48 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Definately looks heat related to me.....
Check IAT's and pump
Old Jan 20, 2011 | 05:18 PM
TheVazha's Avatar
W213 E63
Originally Posted by emoving
How did he check the pump if you do not know where it is?????? My car has 19000 miles and my factory pump was DEAD! They warrantied it with the new BOSCH MB replacemnt and the difference was absolutly amazing.
For $150, it is worth the relpacing. Let me know, I have a brand new one in the box from EC.(CM30)
Thanks dood. I dont know where the pump is but I'm assuming the tech did. Thank you for the offer as well, I spoke to my buddie at the dealer and he says its a warranty issue and he'll swap it out for me np...
How do I check IAT? As far as the pump I'm already confirmed for a Monday visit to the dealer. As far as numbers, what should I be putting down with the 180mm and "Jerry" tune? Again, the car is a monster, I get wheels spin in third gear (I also have crap for tires, Nexin). Should I get back on that dyno after I replace the IC pump? Does the IC pump controll the IAT?
If these are not the problems, what else do you guys think it could be?
Old Jan 20, 2011 | 05:29 PM
Evolved8's Avatar
AMG Fam
How do I check IAT?
With a scan tool that is capable to get into monitoring different engine functions.
Old Jan 21, 2011 | 02:18 PM
Eurohorses's Avatar
2005 E55
Im putting down 505 whp and 575 lbtq with your setup + Larger heat exchanger, pump, and headers. I also had Jeremy tune my car.... You should definitely upgrade your Heat exhanger and pump since you are running a 180mm pulley. Your numbers will definitely improve with those mods.
Old Mar 10, 2011 | 09:36 PM
2004RennTechE55's Avatar
2004 e55, 2006 gmc 3500 van( for work )
Yup
Old Mar 11, 2011 | 09:57 AM
E55AMGGG04's Avatar
04 w211 E55
I put 411/456 stock on a dynojet with a horrible fan. Your def low like every1 says. A bad pump definetly could be the reason. When I had a bad pump my car wasn't even as fast as it is now just stock. After racing same car before and after pump change I saw it was a huge difference.
Old Mar 12, 2011 | 05:52 AM
  #32
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Mine's still stock but changing my dead IC pump made a world of difference. Considering some mods, perhaps starting from the cooling system...
Brgds
Old Mar 12, 2011 | 06:51 AM
  #33
Mantooth's Avatar
2004 E55 AMG
Bone stock, I pulled 366whp and 485wtq on a dyno jet. It was probably over 100 degrees in the shop and mid 90s outside. Can't wait to get it dynoed on a decent day.
Old Mar 12, 2011 | 07:37 AM
  #34
GT-ER's Avatar
2005 E55 AMG
With such high torque and such low hp, are you sure your pump isn't dead? With so many pumps going bad I would suggest that EVERYONE made sure theirs were okay.
My first dyno was 395whp and 437wtrq. Turns out my intercooler pump was half dead ( it would spin but slowly ).
Swapped it out a bam...429whp and 451wtrq. It the pump wasn't even 100% dead.
Old Mar 12, 2011 | 07:44 AM
  #35
Mantooth's Avatar
2004 E55 AMG
It's my second pump. It probably didn't have 5,000 miles on it. However, I think it was just the temps. To be sure, I have an old CM30 and a heat exchanger going on soon.
Old Mar 12, 2011 | 08:14 AM
  #36
TurboTim's Avatar
'12 E550 AWD
Seems like not enough cooling mods to me. When you crank up the boost, the temps go up, so you need more cooling mods to cool them back down. Easy way to see this is if you make more power on the hit, but it tapers off with RPM.
Old Mar 14, 2011 | 06:48 PM
  #37
alextaylor29's Avatar
2004 E55 AMG
Yeah those numbers seem low. (See my sig.) I have an upgraded HE and Jerry tuned mine to match the 180MM pulley.
Could be your pump or perhaps heat soak?
Alex
Old Mar 15, 2011 | 02:32 PM
  #38
ricsimae's Avatar
E55 Kompressor
I had problem with generator , wasn't power.Therefore 0-200km/h + 1-1.5 sec
  #39
ricsimae's Avatar
E55 Kompressor
AMG
Old Mar 15, 2011 | 02:33 PM
  #40
ricsimae's Avatar
E55 Kompressor
Old Mar 15, 2011 | 05:08 PM
  #41
grantwoodtx's Avatar
GLE 63S
Old Mar 15, 2011 | 10:18 PM
  #42
AMGV855's Avatar
E55 AMG
Looks like you got bigger problems than that.
You joined in 2009??? Problem with the generator at home, no power ? couldn't log on?
(your pump had a problem, you had no power and added a few seconds to your 0-200km time)
To the OP, have you had a chance to switch out your pump as of yet?
Old Mar 15, 2011 | 10:21 PM
  #43
TheVazha's Avatar
W213 E63
^ Not yet my friend, I've been busy as hell. Summer is here tho so I do plan to get it done in the next week or two...
Old Mar 15, 2011 | 10:32 PM
  #44
AMGV855's Avatar
E55 AMG
Do you have any idea what pump you are going to replace it with?
I just ordered the updated bosch pump, I have a 180 pulley on the way, hopefully the pump will serve me well. I just have to decide on a H/E now.
I have a pretty good link on the pump, if Bosch is the way you want to go let me know and I will hook you up with the info.
Old Mar 15, 2011 | 11:27 PM
  #45
TheVazha's Avatar
W213 E63
I have warranty so it looks like I'll be replacing it with whatever the stock IC pump is. I thought for a while that my stock IC pump will be sufficient as I dont track my ride.I was wrong. That 180mm pulley produces HEAT...
Old Mar 15, 2011 | 11:52 PM
  #46
AMGV855's Avatar
E55 AMG
Nice, at least it's covered my friend. I was thinking the same way about the stock pump being okay. I like to toy with the car as little as possible, but power in any form is addictive.
What are you running in regards to H/E?
Old Mar 16, 2011 | 01:56 PM
  #47
TheVazha's Avatar
W213 E63
Running stock! Before the pulley I was good to go, after the pulley you really need some sort of extra cooling. Can someone put together a quick list of cooling options including their pros/cons/pricing? Thanks!!!!!!!!!!!!!!!!!!!!!!
Old Mar 17, 2011 | 12:18 PM
  #48
ricsimae's Avatar
E55 Kompressor
It was not enough power in the petrol pump and could not do enough to pressure, so impoverished in the AFR and did not let up the boost, the ECU!
Norbert Haug has electricity at home.
Old Mar 17, 2011 | 01:34 PM
  #49
iAMGod's Avatar
996tt
Man...you sound like your retarded.
To OP - my sl55 is currently having a 175 installed and getting tuned - already ordered a CM30 - im thinking of also going for a larger/ more effective HE - if anyone can recommend a good one to purchase?
Old Mar 17, 2011 | 01:37 PM
  #50
Zmydust's Avatar
996 Guards red / 2008 Hayabusa / 2004 E55 AMG
Actually it sounds like English isn't his first language
