Noise from HVAC Center Dash Vents
Thanks in advance.
http://www.autopartswarehouse.com/sk...3408bff5&lct=s
Are you assuming it is the fan? Or did you solve the problem a few of us are having by actually diagnosing and replacing the fan. I just want to make sure this is what my problem is before purchasing the fan. Definitely appreciate your insight.
Is this the correct fan for our application? Any issues with the install or is it straight forward? Just to confirm, to access the fan motor, the interior panel under the glove box must be removed. Is it right there once removed or are you fishing through wires and other parts to reach the bolts?
Thanks,
Todd
