INFAMOUS AIRMATIC
So being of strong faith and a believer myself I turned straight to the one that some say can answer almost all questions I put my hands together and type www.google.com. So it could be a line, a pump, a shock, maybe a couple other things, okay diagnosis time. So I tow my car to one shop that sounded great on the phone and had some good reviews online (so much for being a believer.) I get the car off the flatbed and insist I drive it down just as I drove it up. The shop tells me to grab a coffee or something and they will call me, even though I insisted I watch. I don't like to leave my car anywhere. I wasn’t too happy but shortly after about a 1.5 hours I get a call to head back, okay so it’s my front right Airshock, but my sensor arm is bent also? How would that even happen? "For now were pretty sure its the shock but you might need the pump as well" he said.
The price he quoted me from the dealer was insane for parts. I asked him if there was any alternative and he said unfortunately not, but I know there is ARNOTT, I’m sure he did too. Anyway I tell him that I can get the shock cheaper but it will take some time and ill bring the car back when I get the parts, he insists I keep the car there over and over. Now why would you want a car taking up room at your shop for a good week at least?
Just from his character I assure you it wasn’t out of the goodness of his heart.
So tow the car home, flatbed arrives, another jerk off. This guy is trying to stare at my suspension and peak underneath telling me I must have broke a spring or something. I said yaaa probably I don’t know, (I can’t be bothered to explain its Air Suspension). This guy refuses to let me drive my car up the ramp, says it’s against policy. I tell him that the last driver didn’t have a problem, he says its there discretion, so I say great guess what my car, my discretion, hit the road Jack. (And don’t you come back no more no more...lol) anyway I’m not an ******* but this douche was covered in oil and grease. I could tell he wouldn’t care to mess up my interior or mar my beautifully detailed paint that was just coated with Zymol Vintage a $2000 wax. So...bye-bye.
Called CAA got another Flatbed, great guy tows car home straps it the way I asked. He made me feel safe about my mistress. I tipped him well got his card and park up the car.
I call Arnott get a airshock, call dealer order a sensor arm, get the car towed again (called the same guy, who took care of me last time)...nice this is a good day... I drop it at a reputable shop that I get my 911 serviced at and they will call me when it’s ready. They call me to pick up my car, so happy to see my tire is not hiding from me anymore, I pay, hop in the mistress and off I go. Boy did I miss you baby...wait. WTF the car is veering to one side. Its just the road, I guess, nope its not, U-turn. I tell the shop my car is now herby and wants to go its own way, they align the car again, same thing.
The new ARNOTT airshock has the car hiked up a few mm higher than the other side. Now I don’t know if Arnott rebuilds the shocks slightly higher so you Have to buy 2 or if because of the age the other side, it is slightly lower, regardless I cant believe this Shi*t, Mercedes recommends changing both at the same time, this could be why. I always thought it was just part of Mercedes’ rape fetish. Anyway summers almost coming to an end and I’m not having anymore downtime its high time to do some double dating and show off the wives and wheels and do some fine dining in style. So I jack up the car grab a socket and a ratchet and a few washers, try a few choices, going for quick spins in between and bada bing perfect height after the second try.
Now this is NOT how I intend to keep my car but had a few questions I was hoping that you can all help me with.
I believe I did have the system recalibrated, they hooked up my vehicle via STAR diagnostic, played with some things, took it for a drive and came back. They did that multiple times however there was still a height difference. Do you happen to know what the procedure is for recalibrating? So I can verify that it was done. Also I know certain input values can be changed, that’s how people lower through Star, however input values should be at the same number for L&R no? If I were to adjust the value to bring the arnott shock slightly lower to match the other side, the input values would be uneven, do you think uneven input values for L&R to correct a difference in height negatively effects the suspension or car? It would save me from buying another shock and the install cost and time, however I figured I might as well do it the right way and put a second remanufactured shock to even the height.
I would greatly appreciate all your advice Thanks so much and I hope you all either have warranty or don't have to experience this pain in the A** problem. On a brighter note, I always wondered what the car would look like slammed...
Last edited by AMGV855; Feb 1, 2011 at 06:37 PM. Reason: Grammar and structure was giving Migraines
I have a replacement Arnott shock on my car..no issues at all.
I don't know why the different ranges of adjustment though. Maybe to compensate for the driver's weight??idk
I'd say lower the most limited corner(in terms of rang) and adjust the other side to match the height from ground to fender. That's what I did. I think changes correspond to +/-(1/8) of an inch per each increment/decrement.
I also think the difference in the range of acceptable values further supports the fact that the true readings are different when car is perfectly level because I doubt anyone would want the car to lean on purpose.
btw, I don't recall MB ever saying they replace both at once. In fact, it seems to have been a complaint by members here that they will only replace the side that's bad when under warranty. I'd venture to say that it's incorrect that MB says always two at a time. fwiw, the Arnotts are old struts with just new rubber.
fwiw, here's the pdf on the MB SDS protocol for the SAS height tests (called 319 Job Aid)
https://mbworld.org/forums/4162263-post9.html
On a side note, if you ever get a chance to put Zymol Vintage on your car, do your self a favor and get it done. It is night and day compared to any other wax out there, its applied on by bare hands after warming it in your palms, looks amazing and is litteraly creates a hydrophobic barrier.
Thanks for your valuable input and the pdf , I may have to do just that and throw it on the alignment maching .
Mercedes reccomends changing both out when one goes, at least Canada.
I know I just read that about Arnott and saw a video on youtube , of someone saying simmilar things about a Landrover airshock from Arnott.
I feel like crap that I went that route, but now that I have one from them thats new, it only seems logical to get the second from them to correct the height diffrence, if it cant be solved within reasonable adjustment of parameters(do you think its better to adjust via star or get another shock?) The Mercedes shock (non arnott ) hasnt failed. Or buy 2 new mercedes shocks and swallow the Arnott shocks loss. I dont think I want to do that. Thanks for all your help
and way to rub it in "Arnotts are old struts with just new rubber." lol
I feel like crap my car only has 43,000 miles on it
My car looks exactly like the posted pictures, the one in the pictures also had Zymol vintage Applied but isnt my car.
Pictures hardly do justice, im sure your car looks great 95% of the look is the prep the LSP just finishes it off.
I don't own the Zymol Vintage, my detailer does and when you purchase it, you do get free refills for life. So for his scenario it works quite well.
I do the chemguys 50/50 limited wax and it looks the same
