Aggressive offset-ers, how low are you?
So, those with experience, please post some pics, and or any advice?
And by aggressive offset, Im talking the 25/28 range
I run a +32 rear on 10.5" rim with a 265/30 tire. No way I can run a +28 with a standard-width tire (285/295). I run -2.5 degrees of camber. I've also had the rear fenders rolled and pulled. You may be able to run a +28 on the rear if you have a narrower rim (9.5 or 10"), for example.
On the front, I run a +19 on a 9.5" rim with 245 tire. Front fenders are shaved and pulled.
As far as how low I am, I tuck about half a tire sidewall
ok
the rim widths are 8.5 and 9.5 respectively. And Im running stock width tires.
I think I might have to roll a little
edit:
Thats how low my rears were for awhile before I painted them blue. Its probably 1/2" higher now
Pics for reference of my ride height and tire tuck:
to OP, if you're concerned about rubbing going up driveways, you will rub if you run aggressive offsets. Mercedes front fenders are not friendly for aggressive offsets, like BMW fenders are. You'll either have to slow down or drive into your driveway correctly (straight on or full-lock turn). Any turn in between will cause my tire to grab the front fender. I could probably avoid this by running a 235 tire up front, but didn't want to run too much of a stretch.
Im just looking to fill out the arches a bit more, a tad beefier look - semi flush without a crazy stretched tire.
I have 245 up front, 265 in rear, and the rear 9.5 offset is 28, the 25 is for the fronts
edit: would a 1/2" wider rim really stretch out the tire? or just a slight stretch. This is my first experience besides the 245 snows on the rear 9"
Nanayaw6, perfect performance in Roswell has an in ground drive on alignment rack that makes aligning slammed cars a breeze (prices and service are top notch too)
A sub 30 offset may require a stretch tire fitment to get to fit properly on a 10.5 rim. Also, you may have poke if you're into that look. I'm not. Haven't seen a sub 30 offset on a 10 rim, but you do have extra room to play with there since your rim is not as wide
What's so special about the alignment rack you guys speak of?
OT fasn8n r u gonna make it to commerce tomorrow?
I found it helps to know when the airmatic levels the car so adjustments are made when she's sitting steady. And of course I had to verify the aligned per amg values as opposed to steel springs setup
