Air/Vacuum leak?
Old Feb 25, 2011 | 09:44 PM
03'55AMG's Avatar
AMG
Air/Vacuum leak?
Whilst I was cleaning the engine bay( with the engine on) I heard what either was a vacuum or an air leak right by the driverside exhaust manifold. It hissed louder as I revved up to 3000 Rpms. It's not constant though. It almost sputters but it doesn't appear to be a BIG leak, just like air coming out of a bike tire through a small hole. I'm also noticing a rough idle. And to those that read my "found split hose under airbox" thread, it is not this hose. Any ideas?
Old Feb 26, 2011 | 10:44 PM
03'55AMG's Avatar
AMG
Anybody?
Old Feb 27, 2011 | 11:56 PM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Hard to tell, these cars make all sorts of 'odd' sounds...! Any other symptoms?
Brgds
Old Feb 28, 2011 | 01:07 AM
03'55AMG's Avatar
AMG
There's no CELs, just a hissing sound and rough idle. Car has also ben running 10-15 degree celcius warmer than usual... Very weird. Trying to get the codes (if any) pulled, but nobody near me within 40 miles can do it.. Lol
Old Feb 28, 2011 | 05:42 AM
Roverron's Avatar
ML63
Try taking high resolution pictures with good lighting where you are hearing sound and post them maybe someone will see something you don't
Old Feb 28, 2011 | 03:05 PM
03'55AMG's Avatar
AMG
I could barely fit my hand in the area its coming from, let alone a camera.. I'll try and find a side view picture of the M113 and circle the area in paint
Old Feb 28, 2011 | 03:28 PM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
it's a vacuum leak. had one couple months ago, it threw a CEL. You will need a clamp that's all. Take a look at it in the morning, it's right behind the left bank of the engine toward the fire wall.
Old Feb 28, 2011 | 03:53 PM
03'55AMG's Avatar
AMG
It's not that far back, right by the exhaust manifold close to the Oil input cap thing the engine cover goes over
Old Feb 28, 2011 | 03:57 PM
cal1's Avatar
SL55, ML500 & Acura TL
I had a return (I think) hose from the PCV come loose once. The hose came loose near the drivers side of the TB or near the TB if I remember correctly. It caused slightly rough idle and a stronger than normal fuely exhaust smell. If it is not the vacuum leak EdoubleNickel metioned, let me know and I will snap a photo of the area I am talking about.
Old Feb 28, 2011 | 04:30 PM
03'55AMG's Avatar
AMG
I dont even know if it's a vacuum or air so well see
Old Feb 28, 2011 | 04:37 PM
cal1's Avatar
I missed this post. What I was trying to describe is most likely not your problem based on the location you explained above.
Old Feb 28, 2011 | 04:43 PM
03'55AMG's Avatar
AMG
Maybe Its the exh. Manifold gasket? I just can't seem to pinpoint it.. I know I'm close but I can't feel compresse air or suction.. What would cause high operating temps and a rough idle?
Old Feb 28, 2011 | 04:46 PM
oh ok.
Old Aug 8, 2016 | 04:17 AM
evilpenif's Avatar
E55 Estate
Did you ever get to the bottom of this?
