Aggressive offset tire help.....
Old Mar 2, 2011 | 06:52 PM
pukicabuki's Avatar
e55
I'm looking for some insight from people running an aggressive offset.
The rears are 20x10 +31.
I'm interested in knowing if I can run run a 275/30/20 or should I play it safe and run a 265/30/20.
The fenders will be rolled and pulled. Possibly some negative camber.
Not looking to slam the car or anything. Just be able to run it in S2.
Help is appreciated.
Old Mar 2, 2011 | 08:22 PM
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
I think that would work with a 275 and no fender rolling but I'm by no means a master on offset for this car.
Old Mar 2, 2011 | 08:30 PM
bmontalban's Avatar
2007 E63
for comparison, im running 19x9.5 +35. 285/30-19. dropped about 1", and in s2, I tuck tire in the back. no rubbing, possibly only a couple mm of clearance.
this calculator, http://www.1010tires.com/wheeloffsetcalculator.asp , says it will extend out 10mm over my setup.
Old Mar 2, 2011 | 09:12 PM
tbone's Avatar
E500 Sport
275/30 is too tall. If you're not slamming, a 275/25 may work. For reference, I run a 20x10.5 +32 with a 265/30, also rolled and pulled fenders, but I'm slammed.
Old Mar 2, 2011 | 10:29 PM
pukicabuki's Avatar
e55
Does anyone even make a 275/25/20? I haven't seen any on tirerack or discount tire.
The extra height was one of the things that concerned me.
I don't have any plans to slam the car. Just sport 2.
Old Mar 2, 2011 | 11:43 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yokohama makes one:
http://www.onlinetires.com/user/vehi...allbrands.html
Old Mar 3, 2011 | 12:37 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
i will also have to look into the yokohama's since they are the only ones that seem to make the sizes like this that i need. i have purchased from onlinetires.com before. great prices.
Old Mar 3, 2011 | 12:45 AM
tbone's Avatar
E500 Sport
Yokohamas tend to run wide increasing your chances of rubbing. Nitto invo comes in a 275/25 as well and the sidewall is more rounded
Old Mar 3, 2011 | 12:51 AM
ohlord's Avatar
Why not
19's?
19x8.5 30et 245/35R19 19x9.5 31et 275/30R19
Brabus ran 20 by 10 on a 38et with 285/25/20's on the rear but that was stuffed and massaged in every direction.
You won't like your ride quality much anymore on 20's
but that's your choice
Old Mar 3, 2011 | 01:04 AM
i just found some Falken FK452 but i think the 265's might be too wide after the low drop
Old Mar 3, 2011 | 07:19 AM
taurran's Avatar
Falken FK452's are probably some of the widest running tires I've ever owned.
