weird drag question
weird drag question
Seeing as a 1/4 heat soaks the engine, would it affect the aerodynamics to do the runs w/o a hood? and would it help at all with the wind on the s/c? usually aerodynamics are important around what, like 100+? and only doing 115-125 mph tops a run wheres the real loss?
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
i think this will be a positive -- you will gain in cooling -- and you can set up a simple RAM air setup by removing the snorkels ---
You could lose a tad in aero and looks-- but you will also gain in weigh reduction --
So - that is 2 big pluses in the performance area -- maybe the slightest negative for wind drag -- and a minus for not looking so good --
Also - a big plus in sound because that Supercharger will whine like crazy.
The following infractions shall result in immediate disqualificatin and competitiors shall not be permitted to race until the discrepancy is corrected:
Convertible running 13.49 or quicker without a roll bar
Motorcycle or snowmobile riders running 10.99 or quicker without leather pants and/or a lanyard
Hardtop vehicles running 11.49 or quicker without a roll bar
Drivers/riders running 9.99 seconds or quicker without a valid IHRA credential
Drivers running 13.99 seconds or quicker without a helmet meeting Snell or SFI specifications
Drivers/riders running 13.99 seconds or quicker with a co-drive
This was taken directly from NEDs site.. I thought I had read 12.5, but it seems to be 11.5...??
I just went threw the pdf manual also and no where does it say 12.5 needing a roll cage.I heard this rumor a few times and was worried that most cars would get kicked out.ill be there april second
wouldnt the steel tubing that comes with the E55 count as a roll cage?? maybe just ad a 5 point harness and youd think thatd be enough in the all mighty life saving 55
E55 AMG, CL65 AMG, S8, S6, E30 M3, Z3MC
At least not at these speeds my friend.
DRAG FORCE ON A ONE-SQUARE FOOT SQUARE PLATE
Speed
Drag Force Horsepower Required
to Overcome the
Aerodynamic Drag
0 mph 0 pounds 0 hp
100 mph 33 pounds 9 hp
200 mph 133 pounds 71 hp
300 mph 299 pounds 239 hp
Basically, areo dynamics do not mean much below 150MPH. A quick history lesson is from NASCAR when they would trade hoods and front fenders on the super-speedways and still win. Talk about drag
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
2003 porsche 996 turbo
heres the roll cage rules
http://www.nhraonline.com/contacts/tech_faq.html
E55 w/ goods, Z32 Project underway
I've seen a 55 with a removable roll cage in it, but seriously if you can get your fastest passes at a track rental why go and slaughter our cars even more just to be allowed to run below 11.49
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
as much as i like drag racing, no more test and tunes for me..And i was planning to make a NED appearance this summer but with those new rules no way![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
