CEL code 2187
Old Mar 9, 2011 | 06:40 PM
julian14's Avatar
E 63 amg
CEL code 2187
Hi guys i have a 07 e63 with 45k/i took out the charcoal filter about 8 month ago since then its been throwing the CEL on and when i check codes 2187=system too lean at idle bank 1. on occ the light goes off by itself but here recently it has stay on for days now until i delete with my OBD2 scanner
any help would be appreciated
the car runs strong no issues the dealer cannot figure it out
thanks in advance
Old Mar 9, 2011 | 07:03 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
I think I could help this also drove me crazy . there was a tsb for leaking intake gasket for 07 e63
there are new bolts and new gaskets to fix this . it toke me around 2h to do .I also found the rubber at the base of the Y pipe that goes from the 2 airboxes to the back was getting hard and leeting air by. this gasket is arund 20$ , the intake gasket and bolts were also cheap
good luck read this feel free to ask questions
https://mbworld.org/forums/cls55-amg...-manifold.html
Old Mar 9, 2011 | 08:20 PM
gonzales25's Avatar
Slow
Check your dipstick, see if it came un-seated..Mine used to get pushed out, I replaced it with a new one and never had the problem again I threw the same codes your getting.
Old Mar 9, 2011 | 09:39 PM
julian14's Avatar
E 63 amg
thanks guys i will take back tomorrow to dealer tomorrow still under warranty
i will let you guys know what happen
thanks a million guys, you guys rock
Old Mar 10, 2011 | 08:54 AM
julian14's Avatar
E 63 amg
Hey guys is there a Do it yourself instruction thread? also what is the torque spec on the bolts?? thanks in advance
Old Mar 10, 2011 | 09:26 AM
ertech's Avatar
If your car is under waranty print the link in my first reply(I put a link)
All the tab info is there.
Old Mar 10, 2011 | 10:43 AM
julian14's Avatar
E 63 amg
thanks for the help Ertech, i screw up when i first pull the codes i erase them
i call my SA this morning and told her she said that the engine light needs to be ON in order to pull the codes again.
the P2187 has been coming on/off for the past 8 months but now here recently has stay on for a while.
the car in the morning always has a slight missfire/splur once it warm up it resolves.
the other code i forgot to tell you guys was
P0456-evaporative emission system leak detected. very small leak
so now i have to wait to this code pop up again and take back to dealer
thanks again boys
Old Mar 10, 2011 | 12:02 PM
ertech's Avatar
I pm you my number call me will tell you what to do
Old Mar 12, 2013 | 01:00 PM
Osgee's Avatar
W211 E55 AMG & W163 ML270
Did this get solved ?
Old Mar 12, 2013 | 02:00 PM
j bro's Avatar
2009 C63 ///Amg
Good thread I have been having this problem as well
Old Apr 5, 2013 | 06:01 AM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
Bump!
Same P0456 CEL here. Anyone having any luck tracking this down?
Old Apr 5, 2013 | 08:26 AM
Osgee's Avatar
Originally Posted by jayjmuir
Bump!
My cel code was down to one of the following things,
The map was to agressive on part throttle/idle
And one of the airfilters and cracked
So tge filters were replaced and the map was adjusted on part throttle and ive not seen the cell yet
