HELP! Anyone know what's wrong?
So I went to work this morning and everything is fine. Then I'm leaving and once I start the car I hear a slight whine. It then says electrical consumers are switched off. My heater isn't blowing hard at all, even at full and defrost. Then my radio says battery low and to start my engine or the system will turn off in 3 minutes. Then my Abs light starts to turn on and off. Then it stays on and the ESP says it malfunctioned. Then the screen turns red and say Brake Longer Stopping Distance, and Brake reduced braking effect. Then my Brake light turns on along with the SRS light. So every light is now on. I get to my stop and turn the car off and tried to start it again. It won't even crank now. Has anyone experienced this before? What is wrong and what needs to be done? Any help would be great!
Thanks Again Guys!
Ty
Thanks Again Guys!
Ty
It won't crank at all. The car will start when jump starting. Then will die a little after you disconnect. I'm 99% sure it's the alternator. I'm bringing her to Mercedes to get checked now..... anyone have any lube I can borrow
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Maybe just voltage reg. Good DIY. https://mbworld.org/forums/w211-amg/...lternator.html
1 Post
05 E55 AMG
