Updated E63 instrument cluster!
2004 E55, 1997 E320 "Sold"
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Look what I found. A great deal for anybody looking to update their stock cluster. I don't need it or I would have bought it a while ago, but thought I would give you guys a heads up ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
http://cgi.ebay.com/ebaymotors/Merce...#ht_1035wt_722
Yeah that is what he meant lol. The A is the beginning of the part #. The retail cost is over $1500 at the dealer. I just got a new one or else I would be all over this!
Viper SRT-10, 68 Camaro
In order to have it programmed it MUST be brand new with it never being in another car. The redline is simply a gauge as abrim stated, so it is basically for looks. The cluster needs to be programmed with STAR and it will work no problem with the e55. The dealer charged me for one hour labor even though they said it took a little longer. Hope this helps.
In order to have it programmed it MUST be brand new with it never being in another car. The redline is simply a gauge as abrim stated, so it is basically for looks. The cluster needs to be programmed with STAR and it will work no problem with the e55. The dealer charged me for one hour labor even though they said it took a little longer. Hope this helps. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Awesome thanks for the help man! May have to jump right on this! I love the black gauges, is it you that has the blue interior lights also? I bet that looks amazing with the dash! I'm going to e-mail him to find out if it has ever been installed, says 0 miles but who knows!
BTW, I will start a thread when I get my car back with a few surprises that some might not expect due to having a great service representative!
True. The problem is that they don't require 12v, but less. The thing is though, if u put three in with a single regular stock bulb than they will work. So, I need to wire up the one led bulb to trick the car thinking it is a 12v stock bulb.
Yes I have the blue lights
They look awesome at night, and with the new cluster it just makes me
On the cluster that is a very good idea to make sure it has not been installed because even if it has zero miles it will not work. For example, I bought a "new" one with zero miles from a seller in Germany that came out of a brand new CLK63, yet Mercedes could not program it because it was "learned" already by another car. Just helping you out so you do not get screwed out of $600 like i did! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
The car is at the dealer and they called me and said they "fixed" the problem by putting the regular bulbs back in lmao. I guess it will be up to me to figure out a solution. On the other hand, my car had a leak in the gas tank which was causing a check engine light, so that was good they got that fixed.
BTW, I will start a thread when I get my car back with a few surprises that some might not expect due to having a great service representative!![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
haha that would be some funny/bad sh*t if redline went based on the gauge. my e55 sounded amazing and a lot higher pitched than normal, but then a piston went through my hood and into a store window!!
![](http://public.blu.livefilestore.com/y1p53tlntr0QxOLSKzqivD1wBw1fQkHEGbmzHHsjgQHSsxKmYzzfza7K9y3CiZ9CdVS7cVEXc5fqdcjDhIP1FYLDQ/IMG_1124%20(1024x768).jpg?psid=1)
star also seems to let you set a cluster back to 0. i was fooling around with the options and it had the option. i am going to be changing to a new cluster and will try set it to 0. then I can try to add mileage
Let us know if this works out for you
I wonder if the additional features like oil temp and lap timers are available after the swap.
