Car not starting and stalling, help guys.
Old Mar 13, 2011 | 08:10 PM
Bipasha493's Avatar
CLS 55 AMG
First of, i decided to post this in the w211 E55 section because its frequented more and im hoping to get more answers. Its a 2006 CLS 55. Went to my local grocery store around the corner, parked up and came out back within 10 minutes. I made an attempt close to 5 times to start her up but she wouldnt budge, she would crank but wouldnt start fully....as if she ran out of gas...keep in mind i jus filled up yesterday and she is well above half tank. I also had a couple of incidents when she would just stall out while going around 5 mph. Is this the infamous fuel problem we are all having in our cars? Fuel pump relay? Or the fuel pump? Any help feedback or help is appreciated
Old Mar 13, 2011 | 08:15 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
check the FP fuse
open the tank filler cap and listen if the pump is coming on..
see if you have pressure at the fuel rail. no CEL...before problem..
Old Mar 13, 2011 | 08:23 PM
Bipasha493's Avatar
CLS 55 AMG
ok...im still learning, but how do i check the pressure at the fuel rail?
Old Mar 14, 2011 | 12:14 AM
Hellzno's Avatar
E55 AMG
maybe crank position sensor?
Old Mar 14, 2011 | 01:48 AM
03'55AMG's Avatar
AMG
+1 on cps
Old Mar 14, 2011 | 02:49 AM
tbal's Avatar
Haters crazy
As per my reply to your pm...
Replace cps, replace fuel pump relays
Old Mar 14, 2011 | 11:15 AM
KLR CLS's Avatar
CLS63 PP
Agreed, start at CPS.
Old Mar 14, 2011 | 11:17 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
CPS...just had mine done under warranty with only 19000 miles.
Old Mar 14, 2011 | 12:43 PM
sunil517's Avatar
after talking to the person I am going with CPS also
he had CEL on and the car was stall and crank a bit before turning over.
I was hoping he was able to test for fuel pressure which would mean his relay pump are all working.
Can someone send him a PIC of where the CPS is located?
Old Mar 14, 2011 | 01:02 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check my DIY thread
Old May 16, 2011 | 03:10 PM
icecream's Avatar
W211 E55 - W209 CLK (gone)
question guys. I just have my cps replaced two weeks ago. Yesterday, same thing happen, it would crank but didn't start fully. I have to wait for it to cool down for about 2 hr before i could start it. What other parts that could be wrong?
Old May 16, 2011 | 03:47 PM
shardul's Avatar
first thing to do is pull the error codes off the car. it may be a faulty cps unit.
Old Jun 22, 2013 | 10:10 AM
Ike Luv's Avatar
2005 E55 AMG / 2008 GL550
Im having the same problem right now. I replaced my cps about 3 months ago. Did you find out what it was?
Old Jun 22, 2013 | 12:47 PM
chawkins2001's Avatar
2006 E55 AMG
Your pumps could be going bad, I had a similar issue and one of my pumps was a gonner.
Old Jun 23, 2013 | 05:57 AM
Ike Luv's Avatar
Did it throw any codes? Cause I'm not throwing any...
Old Feb 8, 2014 | 04:17 AM
jay_55's Avatar
E55 AMG
I have done new fuel pumps & relays, engine sensors, new ignition & keys, service and now I have had the tracking unit removed from the vehicle as well as it has a fuel cut off.
what I find strange is that when my car shuts down I have no power to the fuel pump, 12v cigarette lighter and well as the front power seats.
I think the dealership is saying there is no power going to unit 30 or 36 which control all those systems.
I have spent in the region of $3500.00 trying to sort this problem out and no luck.
I'm really stuck and confused as to what could be the problem.
if anyone has any info it would really be appreciated.
Old Feb 8, 2014 | 08:17 AM
mAMG's Avatar
SL55 2003
If not CPS, then it might be Fuel relay.
