Any opinions on the w211 KMAC camber kits
Old Mar 18, 2011 | 10:00 PM
hollandca12's Avatar
Hey Guys,
After 3 years of replacing tires roughly every 6 months due to inner tire wear (negative camber) I've begun to look into the KMAC camber kits. After looking through a few old posts I couldn't find a consensus regarding their usefulness or reduction in uneven tire wear. Soo before I pulled the trigger I wanted to get others thoughts/opinions..... I guess do they really work? What's involved in the install?
Thanks in advance
Old Mar 19, 2011 | 12:05 AM
£ C43 £ AMG £'s Avatar
E55K AMG
Originally Posted by hollandca12
Hey Guys,
Thanks in advance
I personaly recomend them highly and yes the really do what they say on the packet.
I had the same problem every 3 months with no problems since the install over 6 months ago, tyres are still like new.
Also had the castor adjusted all the way forward which was not possible before and the steering feels positive and tight for this reason and the bushes being stiffer.
Fitting is fairly straight forward but I could not do them with the tool supplied, I had to use a TON press.
Old Mar 19, 2011 | 12:15 AM
ok.... so probably not a DIY project?
Anyone else?
Old Mar 19, 2011 | 07:54 AM
Roverron's Avatar
ML63
I'm looking for feed back on this as well. I'm thinking of pulling trigger on a set. I have not found any resultsafter install. Would a typical alignment shop be able to install these and then align the car? Or should one go to the MB stealer = "More Blood" please oh yea they usually don't ask they just take?
Old Mar 19, 2011 | 10:22 PM
bueller.....bueller.....bueller....
Old Mar 20, 2011 | 12:20 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
there's really not that many people that have done this since kmac only just started making these for the w211 after the platform was nearly out of production.
Old Mar 20, 2011 | 02:06 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
and kinda expensive if you ask me
Old Mar 20, 2011 | 02:28 AM
Jasoneo5's Avatar
W211 E55
Your bad tire wear could be because of worn ball joints and thrust arms as well.
Old Mar 20, 2011 | 09:02 PM
E55K AMG
Anyone else?
Not really, I started it in the driveway of my house and spent hours trying to press one bush out with no luck.............................................. ... then spent 1 hour at my friends workshop using his press and replaced all 4 bushes.
I thought the pricing was cheap considering no one else makes them and normal non adjustable poly bushes can be around this price...... these poly bushes will last a hell of alot longer than the originals rubber ones, so another saving ontop of the tyres.
By the way how are your rear tyres? I had the same front wearing issues also...........
Old Mar 20, 2011 | 09:13 PM
well- if my oem bushings go bad - i will consider this upgrade -- just wish there was more feedback
Old Mar 20, 2011 | 09:50 PM
Front tires don't seem to wear as fast as the rears. Ok thanks for clearing up the install. I guess i should contact my local indy shop and see if they would be up for the install.
