another EV12??
Old Mar 31, 2011 | 11:25 AM
scowil's Avatar
e55
another EV12??
Buddy just sent me a link, looks like there will be several E V12 tt cars running around....
http://jalopnik.com/#!5787579/this-7...f-ev/gallery/1
Old Mar 31, 2011 | 12:21 PM
BenzoBoi's Avatar
Super Moderator
W221
Old Mar 31, 2011 | 01:08 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
only in dubai...
Old Mar 31, 2011 | 02:36 PM
V12Godspeed's Avatar
Your worst nightmare...
Marcin (SPEEDRIVEN) told me about this one. It has their full package (turbochargers, IC's and Intakes). Very impressive.
Old Mar 31, 2011 | 05:18 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
but does it run (properly)?
Old Mar 31, 2011 | 05:40 PM
I think it does..It made 702 rwhp... That should do it.
Mines should be out the closet soon, what's killing me is that I had to be greedy and go with aftermarket set up. If I would have simulated the stock set up I would have been running 3-4 months ago.
Old Mar 31, 2011 | 05:44 PM
BenzoBoi's Avatar
Super Moderator
W221
Don't even sweat it amigo! We all know if you had everything stock, you would have been back in the shop around this time to upgrade everything anyways!
I am definitely look forward to your ride!
Old Mar 31, 2011 | 06:03 PM
Hahah, Not sweetin it sun! I am going for the kill.
Old Mar 31, 2011 | 06:11 PM
BenzoBoi's Avatar
Super Moderator
W221
I'm seriously more anxious to see your car done than mine.
Okay back on topic
Old Mar 31, 2011 | 08:04 PM
03'55AMG's Avatar
AMG
Okay back on topic
Just one more off topic question, When will your V12 55 be done V12?
back to topic;
I wish i could do this
Old Mar 31, 2011 | 08:47 PM
back to topic;
We are shooting for this weekend, We encountered fuel and misfire problems. I think it is due to the bigger injectors.
Old Mar 31, 2011 | 09:32 PM
alextaylor29's Avatar
2004 E55 AMG
Is this convertion as expensive as I think it would be? (Vs. just buying a 2006 S65?)
Looks monsterous!
Alex
Old Apr 2, 2011 | 12:58 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
it is not a conversion. it was a Brabus V12 with 700hp. and a Turkish guy tuned it in Dubai and gave him about 100hp more (guessing it was two lean from the engine inside), and after 2 days the engine broke down. the owner took it to a shop in Abu Dhabi, Mussaffah to fix it. but the engine was really messed up internally. so the owner asked from Brabus for an engine and they quated him 50k USD. so he just went the cheaper way and got S600 engine and replaced it. the car is not even 700hp anymore on the crank. yet saying 700RWHP.
it is slower than wthat it used to be as stock V12 Brabus.
Old Apr 2, 2011 | 02:30 AM
chiromikey's Avatar
thanks for the info, i had a feeling there was more to this story...
Old Apr 2, 2011 | 08:38 PM
Thericker's Avatar
V12-Biturbo
That makes ZERO sense, it has ALL Speedriven IC/CAI/Larger Billet-Turbo upgrade mods on a 600tt engine, Speedriven recently added ONLY larger turbos + CAI/IC setup on a 2003 CL600 & made 611 rwhp 745 rwtq on 91 ECU tune for CA sh*y gas, on factory cats w/zero exhaust work, that power was also NOT just peak hp/tq but made @ 23-24 psi nearly thru ENTIRE rpm band.
The Dyno's are on this forum look it up if he added exhaust work, no or hi-flo cats & 100-109 ECU no doubt kissing 700 rwhp
Mike Spinelli — V12-powered Mercedes-Benz E-Class with two turbos and 700 hp at the wheels. The collaboration matches the hardware and geek bits of Chicago's Speedriven with the shoehorning expertise of ALSA Automotive Engineering of Dubai. ALSA swapped in the 12-can, fitted with gear Speedriven devised for the V12 S-Class, including billet-wheel turbochargers, top-mounted water-to-air intercoolers, "scorpion" air intakes and larger fuel injectors — all overseen by Speedriven ECU and TCU software.
Old Apr 3, 2011 | 12:38 AM
Ali_E55's Avatar
their dyno my friend shows a stock mini cooper S 400hp on the wheel ^_^.
i was there when they are doing this car. thats why i know the full story about this car.
replaced the totaled Brabus V12 with a S600 engine + mods to make it give more power.
i am willing to challenge this car anytime any where with my slightly modded E55
Old Apr 6, 2011 | 04:36 AM
sayegh87's Avatar
BMW 650i Supercharged
Ali, you mentioend that is was slower then then the original brabus engine, well obviously a stock v12 600 engine with brabus turbo's and software will never be anywhere near as powerful as the original engine the car came with... Also its true we had issues with the dyno, but that was a while ago... All is well now... This is the same car you saw, but not with the same upgrades, what it had before was modified or I should say fixed turbochargers from the original brabus engine and software, nothing more... You cant even press full from zero now, its crazy fast... Get your facts and "stories" right before you start blabbering on the internet
Old Apr 6, 2011 | 06:36 AM
Ali_E55's Avatar
so lets get this right
1) it wasn't a 55 and converted to V12
2) it only has Brabus turbos and ECU tuning + S600 stock engine 5.5L
and with only these mods it is giving 700+ RWHP ? while Brabus has these mods + 6.3 V12 and they are saying it is 700hp on the crank.
nice to know ^_^
don't get me wrong, i know your guys in the shop are handy and good mechanical guys and they fix messes others did.
PLEASE read what was written on the website that it was a full convertion (while it is not) and correct the information for them.
Old Apr 7, 2011 | 08:14 AM
sayegh87's Avatar
nice to know ^_^
Hey Ali, thanks for the comment... Regarding the car, when we got it it had a damaged engine from some tuner playing around with it as you know. The engine was a V12 6.3 as you mentioned from Brabus. We took that out since it was in really bad shape, and put in a 600 engine that was supplied to us, this is not something easy even if it might look like a direct swap.
We then took the turbo's off the Brabus engine, rehauled them and installed them on the 5.5 V12 and modified the ecu, which was making some where close to 680 hp (crank)...that was it since the turbo's that came with the 600 engine were in really bad shape.
So the next stage we did was swap the turbo's to speedriven's set up, intercoolers, intake and all the other parts that came with their package, which is what netted us the 700~ wheel hp figure.
So if I get what you mean, we did swap the engine and do the upgrade, we did not just install the modified parts from Speedriven....Is that what you meant? Let me know and I will do my best to answer your question
Old Apr 7, 2011 | 08:52 AM
I want to see Ali's car and the EV12 run, that should settle the score.
Very ncie work
Old Apr 7, 2011 | 09:38 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
Very ncie work
+1
Old Apr 7, 2011 | 05:31 PM
Thericker's Avatar
V12-Biturbo
Very ncie work
I have a feelin Ali, would need the Bi-nocular modification to still the Bi-turbo EV12tt way out in front
Old Apr 7, 2011 | 05:35 PM
Thericker's Avatar
V12-Biturbo
it is not a conversion. he just went the cheaper way and got S600 engine and replaced it. the car is not even 700hp anymore on the crank. yet saying 700RWHP.
Don't you love when other members know what you've 100% done/modded on your own vehicle vs the actual truth lol..
"sayegh87" What total PSI are you running? What's the ECU tune set for, 100-109 octane? Or? What about exhaust work? Thanks very cool project indeed..
Please post vidz!!!!
Old Apr 8, 2011 | 04:10 AM
Ali_E55's Avatar
Very ncie work
i also want to see my car VS this one.
if the owner is willing to race, than I am 100% ready. i want to see my poor slow E55 540rwhp vs this 700rwhp ^_^.
i hope it is sometime soon. because i am selling my car for a great price that won't be offered again.
Old Apr 8, 2011 | 07:36 AM
ahmad0658's Avatar
Brabus K8 E55 05
I would love to join you both Ali and Saygh87 (is that you from ALSA? then hello )
