Check engine light, Small evap leak detected
Old Oct 22, 2023 | 02:27 PM
  #51
Skorp's Avatar
2005 Mercedes Benz CLK 500; 2007 CLK 63 AMG; 2014 E350; 13 Porsche Boxster
Evap leak from each gas cap tried.
I hope I can bump this thread as I am on my wits end on resolving this issue as I can't pass state inspection. I've gone through 4 aftermarket gas caps and 2 of them shows large leak and the red check gas cap message, one said very small leak and my current one says small leak. Should I just go ahead and spend $90 on OEM gas cap and that will be a for sure thing as aftermarket gas caps are just not good anymore? The thing is I've had this issue each year for 3 years and a new gas cap always resolved it each year before state inspection, but this is the first time I had to go through so many gas caps and have not resolve the issue.
Old Oct 23, 2023 | 11:46 AM
  #52
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Are you sure the EVAP canister isn't leaking?
Old Oct 24, 2023 | 11:50 PM
  #53
Skorp's Avatar
I did check. No leaks from there or don't smell anything. It is tight and secure. Unless there is some professional method I need to do to test it?
