DIY: Removing scratches from COMAND screen
The title is somewhat misleading.
What most people characterize as scratching of the screen is actually a scratching of the anti-glare coating that is applied to the screen.
Either way, a careless P.O. used some sort of abrasive or overly-aggressive cleaner on the screen and the result is a screen that looked like this:
![DIY: Removing scratches from COMAND screen-dsc04354.jpg](https://mbworld.org/forums/attachments/w211-amg/381961d1542321903t-diy-removing-scratches-comand-screen-dsc04354.jpg)
After a few moments spent on this site and the search function, I found a thread that insisted that this fix was dead-simple and easy to do. The concept was simply to find a gentle cleaner that would remove the remainder of the anti-glare coating from the COMAND screen and give it a uniform appearance.
I bought this package for less than $10 from Amazon.com
![DIY: Removing scratches from COMAND screen-dsc04356.jpg](https://mbworld.org/forums/attachments/w211-amg/381962d1542321903t-diy-removing-scratches-comand-screen-dsc04356.jpg)
OK, Let's begin.... this process is quick and you will literally spend less than 15 minutes completing this repair.
STEP 1: Tape off the surrounding area to prevent getting the cleaners in the crevices where they are not wanted. Start with the #2 Scratch remover...shake well and apply a small dab to a lint-free cloth. The kit I purchased actually included a few cloths with it, but any microfiber cloth would be fine. The smaller the better, so you can get into the small corners, etc.
Polish the screen with gentle pressure, and work your way around the screen until the anti-glare coating is removed completely. Flip the cloth or use a clean corner to clear away the haze as the polish dries...
Here is an "in process" shot....most of the screen has been polished, but you can still see the anti-glare coating in a band across the lower 1" of the screen.
![DIY: Removing scratches from COMAND screen-dsc04358.jpg](https://mbworld.org/forums/attachments/w211-amg/381963d1542321903t-diy-removing-scratches-comand-screen-dsc04358.jpg)
STEP 2: Once you have removed all of the anti-glare coating and polish residue, you can follow up with the #1 Clean & Shine. This one is much more runny and seems to be more like a protective top coat, so most of the real "work" happened in the previous polishing step.
![DIY: Removing scratches from COMAND screen-dsc04371.jpg](https://mbworld.org/forums/attachments/w211-amg/381964d1542321903t-diy-removing-scratches-comand-screen-dsc04371.jpg)
The result is much nicer. All of the scratches are gone, and the screen has a nice uniform look. When powered-up, it seems that the image is noticeably brighter as well. I suppose there may be instances where the screen may be less visible in direct sunlight, but when the COMAND screen is awash with sunlight, no amount of anti-glare coating is going to make it readable.
![DIY: Removing scratches from COMAND screen-dsc04367.jpg](https://mbworld.org/forums/attachments/w211-amg/381965d1542321903t-diy-removing-scratches-comand-screen-dsc04367.jpg)
That's it! This isn't exactly hardcore "tech" but I figured that since this site has already provided me with plenty of answers and information I'd give back in some small way with a project that will probably help a lot of other folks.
It is an easy process to do, and it really helps to freshen-up the look of the screen and keep the interior looking new.
-G
-G
The following 4 users liked this post by GregMB:
Nice writeup. My screen is still in good shape...but good to know if it gets that way.
Thanks.
Bill
Thanks.
Bill
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
awesome!! the fine stratches I see on my screen when the sun hits it directly is very annoying....I think I will give this a try!
ZAAG makes its popular invisibleSHEILD commonly used on iPods and cell phones available for COMAND.
http://www.amazon.com/ZAGG-invisible.../dp/B0013NBOUS
jmirgy (05-14-2022)
The COMAND system is not a touch screen system....... Stop touching the screen!
No need to add an anti-glare or scratch protector overlay to the screen either IMHO. I've been driving the car with the antiglare coating removed for several weeks now and don't miss it one bit.
-G
The COMAND system is not a touch screen system....... Stop touching the screen! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
-G
-G
w209
How did you polish the corners and sides of the screen? With a lineal movement? It recommends to do round movements. I've done this with the same product and the center of the screen is OK, but the sides and corners look awful as they are not polished at all and have different color
1 Post
2003 CL600, CL2 Sport Package, Eurocharged / 2014 Jeep SRT / 2009 SAAB 9-7X AERO 6.0 LS2
Novus Plastic Restorer Kit
Hello All,
I just finished using this product on my CL600 Command Navigation Screen. If you are patient and follow the steps correctly your screen will once again look new. It will take about 30 minutes and never apply too much pressure. The product worked flawlessly.
My Steering Wheel Control Buttons were also in terrible shape. I had thoughts of replacing them, but at a replacement cost of about $200.00 and taking apart the entire wheel was not a good option for me. I purchased Goo Gone. I used a clean and soft microfiber cloth and saturated one corner of it with the Goo Gone. I worked the product over each button, holding the button down at the corner to stop it from moving back and forth.
My car is a 2003 Cl600 so I had almost a decade of sticky build-up on those buttons. Again, your patience will pay off. I used about a quarter of the bottle of Goo Gone and 30 minutes of elbow grease. I removed the excess Goo Gone, and completely dried the buttons. I then applied Novus #1, to clean and polish the buttons. The buttons are now like new. I greatly appreciate all the posts on this site, they have helped me greatly.
Happy New Year to everyone.
Anthony
Anthony
![](http://i904.photobucket.com/albums/ac249/gregblanchette/E55/DSC04354.jpg)
![](http://i904.photobucket.com/albums/ac249/gregblanchette/E55/DSC04356.jpg)
![](http://i904.photobucket.com/albums/ac249/gregblanchette/E55/DSC04358.jpg)
![](http://i904.photobucket.com/albums/ac249/gregblanchette/E55/DSC04371.jpg)
![](http://i904.photobucket.com/albums/ac249/gregblanchette/E55/DSC04367.jpg)
-G
-G
2007 E63 AMG, 1991 NSX, 2007 Corvette
Greg-
Thanks for the post. This is exactly what I need. Not sure what the previous owner did with the screen, but it looks exactly like how yours did.
Can't wait for the products to show up so I can get the same results you did.
Thanks for sharing.
Thanks for sharing.
2008 S550, 2004 E500 4MATIC Sportswagon, 2007 CL600
Another success story following this procedure. I ruined my AR coating after getting oil on the screen and failed to clean it properly.
I used a soft credit card with no embossed numbers to get into all the edges and corners. I took me about 1.5 hours to polish out every little bit of the AR coating. Finishing with the Novus #1 really does finish it off. Takes a lot of time to buff out the edges and corners.
I agree that you don't need to add AR coating unless you want to protect the screen and I like the look of the screen better now.
Hi all
I have an older R230 SL500 with the smaller screen. I noticed that in the middle of the screen has a couple of air bubbles and now when viewed on an angle, the screen its barely visible, it is smeared / white.
However when viewed straight on, its fine. Do you think it iscaused by the anti-glare ?
Best regards,
Shaun
Best regards,
Shaun
