System too lean at idle bank 1 P2187
Old Apr 20, 2011 | 10:13 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
2007 E63 60k all stock with the addition of KNNs 36 miles ago.
Both stock filters are gone and just the KNNs are in now.
Can this cause engine damage? I am going on a 2,000 mile trip and if it will cause damage I will go get some dealer paper and toss those in.
I was told to remove the plastic behind the grill for better flow but that should cause more air flow and a lean condition.
Why is it only bank 1?
Does the car need a tune to fix this problem with the KNN or should I go back to paper...
I hate to see a CE light...
Thanks...guys...
Old Apr 20, 2011 | 11:52 PM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
mine did the same i did a hyw pull to 150 with the kn filters and the same code poped up its because its too much air but i cleared it and it never came back because i haven't done any 150 pulls
Old Apr 21, 2011 | 07:11 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
+1 here , only on high MPH runs would the light come on , Bank 1 you might not of clipped the box back correctly . i had this happen . make sure they are sitting flush and the scenario is now that you are getting more air flow a ECU tune will take care of those pesky CELS
More air needs more fuel and needs more free flowing exhaust, get the equation ???? pretty simple
Old Apr 21, 2011 | 07:45 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
plug in the OBD2 scanner and check your long tern fuel trims i am sure they are at -25%. this means the ecu has maxed out its correction ability to add fuel.
FYI LTFT should be between -5% and +5% on both banks.
Old Apr 21, 2011 | 07:47 AM
shardul's Avatar
clear the CEL first and do a hard reset on the car but disconnecting the battery for 10 mins, it may solve for problem for the time being
Old Apr 21, 2011 | 11:27 AM
sunil517's Avatar
which side is Bank 1
should I try reinstalling the charcoal filters wiht the KNN?
The car has not been pass 50 mph since the swap. The CE came on one cold evening at idle, shake a bit and the code came on.
Also which side is Bank 1? driver or pass....
I am going to do a hard reset and look at the fuel trim ....
Old Apr 21, 2011 | 12:10 PM
shardul's Avatar
Passenger side is bank 1
What are the fuel trims before the hard reset.
Old Apr 21, 2011 | 05:13 PM
sunil517's Avatar
air box are nice and flat on both banks
LTFT is -1.5 on bank 1&2
STFT is 2.3 on both...
The CE only is on during long idle...
I am going to start a 500+ mile trip tomorrow and then look at the data again and report back.
I will spray some gumout and see if the idle change when I hit around the air box.
Old Apr 25, 2011 | 06:27 PM
sunil517's Avatar
update
after 1300 miles
LTFT B1 -9.3
B2 -7.0
Fuel Pressure is 43 at idle...
No CE light on during the trip. Do you think the ECU is not learning the new air flow..
Old Apr 26, 2011 | 08:59 AM
chawkins2001's Avatar
2006 E55 AMG
I threw a one bank lean code and it turned out to be a bad o2 sensor ftw.
Old Apr 26, 2011 | 10:13 AM
sunil517's Avatar
do you have stock paper filters or KNN?
I am thinking of going back to OEM paper filters I hate to see CE light.
