Carbon Ceramic
Old Apr 23, 2011 | 01:50 PM
Oxygen's Avatar
W220 S65 AMG
Thumbs up Carbon Ceramic
What's crackin' cuz?
Old Apr 23, 2011 | 01:52 PM
Oxygen's Avatar
W220 S65 AMG
Rotor is like $2,990.00 from the new E63 with ceramic brake option...
Old Apr 23, 2011 | 02:28 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Whoa!
Old Apr 23, 2011 | 04:54 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
its...its... BEATUTIFUL
I'd hug that to bed every night... haha
Old Apr 23, 2011 | 05:04 PM
AMGPilot's Avatar
2004 E55
Nothing wrong with that rotor
Old Apr 23, 2011 | 05:09 PM
ahmad0658's Avatar
Brabus K8 E55 05
Heat till extra hot temp, then get cold suddenly "could be cold water, etc.." and then heat till extra hot temp and get cold quickly, and the cycle continue for some times !!!!
Old Apr 23, 2011 | 06:01 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Only 6 piston
Even old school e55s had eight pistons.
But I do like the rotor
Old Apr 23, 2011 | 08:04 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
suppose its jus tfor one piece, right ?
do you have a pic showing it horizontally ?
it just seems the same make as first SLR rotor's version rather than those Brembos lately mounted on 722's ..
Old Apr 23, 2011 | 11:02 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Seems MB finally sourced some goodies from the PCCB supplier.
Old Apr 24, 2011 | 01:38 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Very sexy, but the price is deadly!
Old Apr 24, 2011 | 01:51 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
How much do those weigh? whats the savings in lbs?
Old Apr 24, 2011 | 02:24 AM
AMGPilot's Avatar
2004 E55
forget about it, they won't work with SBC
Old Apr 24, 2011 | 02:44 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
The SLS GT3 is using steel rotors as are all of the DTM's. There has been problems with carbon rotors scoring from foreign objects. F1 is using them because they throw the rotors away after qualifying and after the race
Old Apr 24, 2011 | 02:46 AM
AMGPilot's Avatar
2004 E55
No F1 uses it for it's thermal properties and it's low weight and while Iron rotors can have excellent decel characteristics carbon beats iron in decel
Old Apr 24, 2011 | 04:38 AM
Oxygen's Avatar
W220 S65 AMG
I think on the rotor it says 7732g
Old Apr 24, 2011 | 05:03 AM
e500slr's Avatar
2011 E63, 2013 CLS63
Wait so 7.7kg from each?
Old Apr 24, 2011 | 05:31 AM
dyno's Avatar
why not, SLR has sbc, iirc
Old Apr 24, 2011 | 11:33 AM
Oxygen's Avatar
W220 S65 AMG
I think... look on the hat of the rotor above it says "7732g" which is about 17lbs if my math is correct.
I don't know if that's heavy or light (how much does a standard rotor weigh?) and I also don't know if the carbon ceramic rotors are supposed to save on weight..
Old Apr 24, 2011 | 03:13 PM
AMGPilot's Avatar
2004 E55
It won't work with our SBC due to fluid volume requirements and programming of the SBC for ESP and stability Managment. Carbon brakes have much different bite than iron and that needs to be taken into account. SBC also calculates brake temp to mitigate fade and again there is a large difference between carbon and iron thermally
Old Apr 24, 2011 | 05:10 PM
dyno's Avatar
so, do you mean that anybody wanting to put those brakes must reprogram SBC and ESP similarly to SLR ?
...or do you know of anybody who installed them without any reprogramming and it was so bad/unmanageable ?
along that route you would need a retune even after upgrading to a different, maybe just a so called "composite" rotor and/or softer brake pads ...
again, do you think that w212 with carbon brake option requires a different ESP setting ?
mmh .. not sure, after all we are talking here something "street usable" Carbon/ceramic rotors: these are not F1 "Carbon/carbon" , these are "C-Sic" Carbon-Silicon Carbide mixture .. much similar in its behaviour at low temperatures to normal iron rotors ..
Old Apr 24, 2011 | 05:18 PM
AMGPilot's Avatar
2004 E55
The W212 doesn't use sbc and it's master cylinder is differently sized than our SBC Master, so it won't work because of that reason alone
Old Apr 24, 2011 | 05:28 PM
dyno's Avatar
yes, that's really lightweight, especially if you consider that those rotors are much thicker and larger than standard (afaik they are 402x39mm).
maybe they are over-dimensioned (but marketing rules here)
also because SLR's first series 370mm rotors were reputed very efficient and the subsequent series, the larger 390mm Brembos were not considered that much better.
if you want a weight comparison: here you are:
Uploaded with ImageShack.us
... and it's real, I weighted myself (well, not very professionally, but still a "made in germany" balance ..LOL)
oh.. btw, those SLS style rotors posted by you are a bargain compared to previous SLR's: if you paste this 1994200472 part number into a partsonline website you'll get a 10K price-list (euros)
Old Apr 24, 2011 | 05:38 PM
dyno's Avatar
infact I didn't say SBC but just ESP reprogram ..
my question was whether the carbon option for W212 or 218 or SLs would require any reprogramming
Old Apr 24, 2011 | 05:54 PM
AMGPilot's Avatar
2004 E55
It doesn't matter the Master cylinders are not the same size and yes it would require reprogramming on a firmware level not a star coding level
Old Apr 24, 2011 | 06:08 PM
dyno's Avatar
if master cylinders are different, then I can belive
so, a new nightmare on the horizon then, because I would like to do that mod ..
