Installing Trunk spoiler with 3M tape or Urethane Adhesive?
Old May 4, 2011 | 03:42 PM
w211e500sport's Avatar
2004 Mercdes E500sport
Hello, Everyone
I just bought a roof spoiler and trunk spoiler and painted already for my 2004 E500 .I want to installed it this weekend and need a few tips..Does anyone used 3m double side tape or Urethane Adhesive or both the roof spoiler and trunk spoiler ? and what is the brand for the Urethane adhesive?
Thanks!
Steve
Old May 4, 2011 | 03:46 PM
Busta Riles's Avatar
1969 280S, 1991 300E
3m tape.
That's how they are installed from factory & that's how i've done many of them.
Old May 4, 2011 | 03:54 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
3M tape is the way to go, forget about the epoxy adhesives. I have installed trunk spoilers and front chin spoilers this way, and can't be more happy about the outcome.
Old May 4, 2011 | 04:37 PM
Mike@Vossen's Avatar
Former Vendor of MBWorld
AMG
3M as well. That's what I did...had no issues. Just make sure you clean well before putting it on. You don't want dust or any other garbage to be under there.
Old May 4, 2011 | 05:28 PM
thanks! for the advice.
I hope it will turn out good this weekend once it's installed ...again thank you!
Steve
Orange County, CA
Old May 5, 2011 | 11:00 AM
TerpsV2's Avatar
E63 AMG
Just installed my euroteck cf rear spoiler with 3m, stuff is strong, just clean the area and wipe down with rubbing alcohol prior to install
Old May 11, 2011 | 03:30 PM
Does anyone know the thickness & Width of the 3M or item # i would need to install for the trunk spoiler and roof spoiler? I have look up but 2 many on 3m website not sure which one is correct. Thanks!
Old May 11, 2011 | 04:05 PM
_AMG_'s Avatar
C63
installed my spoiler with 3m double sided tape. Its very solid.
Old May 11, 2011 | 10:26 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
3m.. Enough said
Old May 11, 2011 | 10:47 PM
timeToy's Avatar
'08 E63 Wagon
3M is great, it will hold, but you have to do a good prep work:
1- Clean the area with soapy water, remove all dirt, dust and sap. (Car and Spoiler).
2- Thoroughly clean the area with isopropyl alcohol. (Essential do not skip, Car and Spoiler).
3- Spray some adhesion promoter (Optional but recommended, you can find it next to the 3M tape at you local auto shop!, Car and Spoiler).
4- Apply the 3M tape to the spoiler (Do not press super hard).
5- Remove the first 3-4 inches of protective backing from each ends of the 3M tape, tape the backing on top of the spoiler.
6- Line up the spoiler without touching the trunk, then install it.
7- Pull the protective backing from under the spoiler.
8- Press hard (HARDER), all across the length of the spoiler.
9- Let it rest for few hours.
Old Aug 1, 2011 | 02:15 PM
jameswh0's Avatar
2014 E63, 2012 QX56, 2014 Jeep Wrangler
Thumbs up
Great info! I'll be doing this later this week!
Old Aug 1, 2011 | 02:27 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
+1
Old Aug 1, 2011 | 02:37 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Had my auto body shop install my spoiler. Only thing I would add to the list above is the following...
1. Buy some painter's tape. The kind that is used to line up the paint lines that can easily be removed. Place the spoiler on the trunk and line it up. Then use the painters tape to mask off the line between the spoiler and the spot where it is being installed. That way when you install the spoiler, you have a guide as to where the spoiler should be fitted without having to guess at the spot.
Old Aug 1, 2011 | 03:31 PM
Bullett's Avatar
2008 E63 AMG
3M has a number of automotive mounting tape, some acrylic, some foam, etc... anyone know the specific 3M product?
Old Aug 2, 2011 | 01:22 PM
jameswh0's Avatar
I just purchased the "Super Strength Molding Tape-03616" from Autozone. It's 7/8" by 180". I seriously doubt I'll be using all of it.
Old Aug 2, 2011 | 03:12 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
I used 3M.
Old Nov 10, 2011 | 02:40 PM
dannish23's Avatar
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
thinking of using scotch double sided tape.. 5lbs strength.. but after reading this thread, i think i will go with 3M if i can find it at Home Depot..
Old Nov 10, 2011 | 04:17 PM
Bramage's Avatar
F-250
Scotch- Made by 3M
