Yet another Airmatic Issue
1. Compressor
2. Relay
3. Strut leaks
I checked for any kind of cracks on the tops of the struts but didn't see anything.
I guess Chrysler Warranty is going to hate me once again.
Any thoughts as to which of the above mentioned problems it might be?
Regards
Here is an update. I went to the garage this morning and she is sitting really low on the front axle, so it IS the whole front end and not one side. I started her up and his the raise car button and it came up about 1/2" but wouldn't raise any further. It gets to about half its' normal hieght and that's it.
If the relay is shot would it do that? Am I wrong in assuming that since it did lift a little the compressor is working?
Thanks for the help guys
Regards
Regards
cant remember off the top of my head, but i believe its located in the front sam, take a peek and see if its blown. there should only be 1 or 2 located in the front sam. if it is blown, replace all three components.
i can give better relay and fuse locations tomorrow.
I can't even begin to tell you how much I wish this car had a steel suspension, may have to do that conversion soon
Anything you can fire my way will be extremely helpful. Thanks again!
Regards
