Dyno Results IN!! Finally after header install
Old May 31, 2011 | 11:55 AM
Evolved8's Avatar
AMG Fam
Here are my results from this mornings Dyno session. What do you guys think....??
I'll load the graph up when I get a chance.
Tempature: 94 deg
Hummidity: 85%
Pulls were done on 20'' HRE Wheels
Dyno: Mustang Dyno (Heart Breaker)
Power: 483WHP 550WTQ
IATs were around 167deg. during the pull
A/F's DEF need adjusted still. I think they are Def robbing power. From 4100 RPMs to 5400 RPMs A/Fs are 10.6-10.9 and after 5500 RPMs A/Fs dip into the 9's Id like to target 11.5-11.8s which is what I'am told is a good target.
Mods: Code3 H/E, Johnson CM03 pump, 180mm ASP Pulley, K&N filters, FF Headers & X pipe, Eurocharged Tune.
Old May 31, 2011 | 11:59 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I would say a shade over 11 at the very top, under heavy load, is about right with a little margin of safety. Sub 10 is going to be killing power.
Old May 31, 2011 | 12:03 PM
jwoodcl55's Avatar
E55 AMG
Nice! I have essentially the same setup, stage 1 w/ 180 pulley, PLM HE, Johnson pump, and res delete. I have the EC long tubes on order and will have three separate dyno's within the next two weeks... Base stage 1 dyno, after long tubes, and then with a EC tune!
Old May 31, 2011 | 12:08 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Was the 167 iat during a pull or is that the average? It seems high to me.
Old May 31, 2011 | 12:13 PM
GT-ER's Avatar
2005 E55 AMG
Me too....I believe this is what's making the car run so rich.
Those numbers are pretty darn good though, especially considering the IAT and the A/F ratios.
FWIW- I have the similar mods pretty much and my IAT's don't go that high in a single run. They might touch 140* but that's tops...even in 90* weather.
Old May 31, 2011 | 12:19 PM
Evolved8's Avatar
AMG Fam
I just want to get the A/F's cleaned up and get some new results. Just talked to Jerry and it sounds like I have some ponies to free up still
Old May 31, 2011 | 12:23 PM
Evolved8's Avatar
AMG Fam
The 167 was the peak on the 3rd pull. Highest on the first pull was 150 With it being 95deg today I didnt think that was to bad. it was 109 up until 4000rpm then went to 120-128 up to 5800rpm and peaked 150 at 6500. at the very end of the pull.
Old May 31, 2011 | 02:15 PM
jmb614's Avatar
E55 AMG
Solid numbers Steve, hopefully everything works out tomorrow so we can release the horses!
Old May 31, 2011 | 03:23 PM
gsxrguy's Avatar
e55,cayenne turbo, supra, sti
was this at brian's shop?
Old May 31, 2011 | 03:58 PM
chawkins2001's Avatar
2006 E55 AMG
That is pig rich and damn good numbers man. I bet once you level the A/F out, you will pick up another 30rwhp. I would get those adjusted asap. You need the TTM fueling kit too
Old May 31, 2011 | 05:27 PM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Impressive #'s!
Old May 31, 2011 | 06:36 PM
Evolved8's Avatar
AMG Fam
Thanks man, Jerry says he is going to handle it before the track day at TimmmayFest. And they claim I shouldnt have to worry about the fueling kit until i do a Throttle body?....
Originally Posted by mikey33
Impressive #'s!
Thanks man Iam hoping for 5xxWHP 57xWTQ when the tune gets cleaned up.
Old May 31, 2011 | 06:37 PM
Evolved8's Avatar
AMG Fam
No It was done at Bradys shop.
Old Jun 1, 2011 | 12:17 AM
Evolved8's Avatar
AMG Fam
What do you guys think about the numbers for being on a Mustang Dyno?
Old Jun 1, 2011 | 09:05 AM
Worth the wait's Avatar
2006 E55
It's just that......a number.
Old Jun 1, 2011 | 09:39 AM
jmb614's Avatar
E55 AMG
I would be interested in the delta numbers really. The difference between stock and current mods, preferably from the same dyno in similar conditions.
Or better yet times on the track
Old Jun 1, 2011 | 09:40 AM
2006 E55 AMG
Is that the target Air Fuel across the rpm range for your setup, 11.5-11.8?
I will have my car finished and tuned this week on a mustang dyno too, so I will post my results in the, "Under the Knife" thread. We have the same setup, except I have a 82mm T/B, no FF headers or x pipe. I also have the stock manifolds, primary cats.
I do have split cooling with trunk mount reservoir/meziere pump, and larger intercooler under the blower though. It is expected to be in the 90*'s all week, so you can also count on shop temps near 100*
I am expecting around 430rwhp/5xxrwtq with my setup. Once I add the Long tubes, I would love to be around 500rwhp on a mustang dyno, so your numbers are super strong imo.
Old Jun 1, 2011 | 10:26 AM
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
Mustang dynos can have corrections applied to say pretty much whatever the operator wants. Many shops that have mustang dynos apply "Dynojet" corrections that are intended to bring them on par with Dynojet equivalents without telling the customers. However, often the Mustang dyno ends up showing more power than a local Dynojet.
You've got some impressive numbers, for sure, but they don't say a whole lot unless you get a before and after on the same dyno.
Old Jun 1, 2011 | 10:32 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
we can go head to head drag racing at timmayfest. That should give you a good feel for how the car is performing.
Old Jun 1, 2011 | 10:42 AM
Evolved8's Avatar
AMG Fam
Sounds good are you on a simmlar setup?
Qutie frankly guys I was just curious as to how it should read on a mustang dyno. I'am more concerned about track times
Old Jun 1, 2011 | 11:40 AM
2006 E55 AMG
Mustang dyno's will never read higher than a dynojet my friend, given all the necessary information is entered correctly where it needs to be. I think mustang dyno's read roughly 18% lower than a dyno jet.
Old Jun 1, 2011 | 12:15 PM
loungn14's Avatar
SPONSOR
eh something like that...lol
Old Jun 1, 2011 | 12:36 PM
GT-ER's Avatar
2005 E55 AMG
More like 10% in my experience. Regardless, I find your numbers pretty darn good but I agree the delta is what's really important.
Old Jun 1, 2011 | 12:45 PM
stevebez's Avatar
Comparing dyno to dyno is pointless... all you need to focus on is the delta on the same dyno...
So I would prefer to know what the before and after numbers were.
Old Jun 1, 2011 | 03:33 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
LOL.......
