HELP! P202B-002 Idle Speed Control Implausible
Any ideas???
- Short circuit to ground or open circuit
i has replaced the boost pressure sensor and has checked for any air leaks it all seem fine.
Engine idles funny (up and down) sometimes. Sometimes it's fine.
Sometimes it feels like it's going to stall. When i switch the car off and back on it seems fine then then the problem comes again !
Thanks Acid
the tb is a 80 mm I brought from a good member of here, is there any other thing that it could be? Shall I put the standard tb back on and will it fit or do i Need the change everything over? And then i need another map ?
Do you know if I lose any power with this issue?
Thanks acid
did you check the hose i was talking about.
I was racing a r8 v10. Last night first run from standstill I gapped him 2.5 cars and then on the second racing I was in front and then bang ! My crank pulley broke off at 120mph lost all power and so much smoke like a ash cloud!
My pulley went under the car hit the sump and cracked it all oil everywhere ! The crack pulley then hit the r8 and and was stuck under his car lucky There was no damage on the r8 someone could have been killed !
The reason the pulley broke is because my crank had a bad wobble and it was expected, so no one is to blame but me! Lol
It was a 180mm pulley asp.
So I guess I need to rebuild my engine now and the tb is the last of my problems.
Acid
Acid
Really sorry to hear this,
must have been a big shock at the time ............ your dash should have lit up like a christmas tree when this happened. If you did not run the car for long dry of oil, it should be ok to just replace the sump ?????????? right?
I really dont want to change my pulley, bad exsperiences time and time agian.
Good luck man
The Pulley was put onwith the right Torque setting ,but the Crank has always had a wobble, so i cannot blame the Pulley to break off under so much pressure.
My Engine is fine and runs, i have a spare sump, but i Need to change my crank!!
i am thinking of putting Forged Pistons ! and to rebuilt the bottom end!
Acid
i got a spare crank as i am a mercedes Breaker! lol
I has the old pulley, i just got a new one from Jerry it arrived today the 180 Asp weld.
I was intrested in the 190mm you had for sale, send me a pm.....
I am going to take the engine out and strip it and see.
Where can i get forged pistons from, ??? looking to run Big power and i need it to take it.
acid
acid
yes wiesco makes some pistons for the 55k
Spent hours chasing wiring and vacuum diagrams, finally gave up and decided the throttle had to be bad. Then I read your post... Checked the rubber evap hose at the left rear cylinder head. It was on there, but loose on the connectors. Threw some zip ties at each junction, problem solved.
Well done.
Well done.
Well done Shardul
Guess what... There is a leak, just a very small one. If they had made that hose out of one piece of tubing it would be fine, instead it's like 4 pieces with little plastic connectors in between.
Also don't forget the thin aluminum tube that goes in to the blower and that get's bumped out when you take the fuel rail off and you don't realize it's off until you try start the car and the same issue with erratic idel etc.
My idle speed is through the roof at 1800-2200 rpm. Car is undrivable. Trying to brake and the car wants to keep going.
I used brake cleaner to see if I can find a vac leak. So far nothing. Took the driver side surge tank off again, took the grommet out of the snout and it feels like it's not really super tight. I placed a zip tie around the hose that pushes onto the aluminum pipe that goes into the snout because that thing slips on and off with little to no resistance. Put the surge tank back on and still nothing.
Came across this post and it seems like I did everything you guys suggested and tried. The TB opens and closes when I press the gas pedal.
I am praying you see this and can maybe shed some light since this is years late..but I had 92mm vrp kit installed and now the car wants to throttle itself and take off when I shift it into Reveres or Drive..shop I have it at has no clue and I’m about to get it back and possibly take it apart again but really am hoping I don’t have to do that..did you ever find what caused it???
sorry man I’m learning as I go and trying to do as much on my own as I can lol so any help is appreciated
