Those who have res/cat delete mods, whats the fuel mpg increase?
i get about 19mpg on daily driving, 23mpg on freeway, so not bad at all.
my plan is to remove the resonator and secondary cats and add straight pipe. NO x-pipe mod.
any thoughts, discussion?
thanks!
Aj
Removed secondary and resonator, places straight 3" pipe on both sides, no x or crossing or touching.
It may or may not gain you mpg, but in my own study after doing it, i notice i get less gas mileage just because i want to floor it more often to hear that nuke go off!
LMAO!!!!
take a tank or two just easy driving, you'd be surprised how well these cars run on one tank?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
