Split IC data log results with new HE and Pump.
I have the ZZP Cobalt HE and Bosch HD 010 pump rigged to run all the time.
Ambient temp 65F
Hwy Crusing IAT temp 90F
2nd gear WOT pull 125F
15 secs recovery to 105
60 secs recovery to 90F
After Split IC
Ambient temp 70F
Hwy cruising IAT temp 80F !!
2nd gear WOT pull 115F
15 secs recovery to 90F
30 secs recovery to 80F
Car feels like it pulls A LOT harder all the time. I did 3 back to back runs with same results, maybe varying by a couple F's...
Im gonna post my own DIY with all parts etc, that is MUCH easier to follow, along side a video made by nanayaw6. Big thanks to him, and 320 Dreamer for tons n tons of info!
Over all for the $50 spent on the IC Split, its WELL WELL worth it.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
