Meth nozzles locations ?
I've run water meth on almost everything I've owned and it's been a great setup, only used Devils own once but have owned most every other brand other than Aquamist.
I don't know if I'd ever consider owning a PD blower car without it, it does too much good. Took my 320 degree inlet temps(might of been higher, my IAT only read to 320) on my old Focus project down to 120 using it strictly for cooling and not tuned for it.
Look forward to your KC + nitrous results. Although, if you're going through the trouble of a wet shot I would go much larger. 100-150 absolutely. If i run a small shot, I go dry typically.
- Drew
i did wrap my nylon lines with heatshielding in the entire engine bay. idc relay is located outside of engine bay by the left front strut tower away from most heat but i still wrapped all the lines going to/from it.
I'm a bit late to the meth party, but I'm now getting ready to install a setup to my car.
I don't know why people don't just relocate the IAT to the surge tank and put the nozzle in the original IAT location. This should avoid having to pull the supercharger and will make nozzle swaps much simpler.
Is there is a reason I have missed?
My nozzles where on the underside of the SC just before the split and I was not able to get to to them.
Smed, the only thing I can think of is most people recommend spraying perpendicular to airflow for best mixing. You would be staying directly into the airflow. I don't know if it will actually do anything or not but maybe it will hurt vaporization and cause larger droplets to form?
There is not much choice in nozzle locations. You want to be after the SC and IC and before the IAT sensor, only place that allows this is the small section at the outlet before it splits into both the surge tanks, however, if you put it there you wont be able to access the nozzles to change them.
My dad has a 300C SRT8 with TVS supercharger and methanol injection. The meth is only injected by a single nozzle after the throttle body. After about 10k miles the supercharger started making a strange noise. After disassembling the blower we found a bad bearing witch was contaminated with water. I'm ready to install my kit, but at this point I'm not sure about the small nozzle after the throttle body. Any thoughts?
according to this, the water should have flashed off before it really accumulated:
https://prometh.com/blogs/tech/72804...n-supercharger
Simple reason could be way too much water. Pre SC usually (depends) helps sealing but not IAT
