Meth nozzles locations ?
Bottom of the line, one nozzle = either before IC or after IC.
Please someone corrects if i am wrong.
You can always just use a single nozzle before the intercooler if you have any reservations about spraying into the blower.
Ive tried one nozzle and two, Ive had it pre IC and post and my current is a M3 pre TB and a #7 pre IC. the difference is around 30 degrees having it pre IC vs Post, I moved mine for 2 reasons, one I wanted a more accurate picture of IAT temps and also I had gone through 2 map sensors in a years time frame.
From Snow:
To add some information to this thread, we have been doing pre-rotor injection for years on all types of positive displacement blower without issue. In fact we recently had a gentleman post on our forums who runs an M90 Eaton blower on a Mercury Marauder. After a lot of heavy injection, he had the blower removed for porting. It looked brand new. We also had an employee with an 04 Mustang Cobra who did a lot of hard driving and is still using the system, probably 3 years plus of injection now with no problems whatsoever.
This not only makes installation easier, it also greatly reduces the blower case temperature and avoids heat soak on repeated runs.
I was also able to maintain peak power through redline.
I disagree. The lower combustion chamber temps allows max timing for the programming. Water/meth slows the burn rate making smoother power and allowing higher pressures without detonation.
I have mine halfway between the end of the core and the IAT sensor, as close to horizontal as I could get it. I'm on E85 so I'm running straight water instead of a meth mix.
Before the water injection, on a 60-130mph pull my IATs would run 80-155°F.
After the water injection, on a 60-130mph pull my IATs would run 80-95°F and flatline... effectively teetering that 95°F barrier when the ECU starts to pull timing
