do you think an 11in wide wheel will fit a 315 tire?
I only ask because my friend has them on his supra and they don't look that wide.im wondering with the right offset if they will fit.
They are only 25.5 in tall so they might clear our cars
on the offset try the stock offset first to see how much room you have to play with on the inside
The mickeys has so much more grip that the bfgs
Ill try to find a 18x10.5 wheel.does the smaller the number offset bring the wheel in closer? So say a 30mm will be 5mm closer to the brakes
if the factory wheel is say and 8.5" wheel and your looking for a say 10.5 " wheel you will need to move the center of the wheel 2" inboard to keep the same et. going to a larger et say a 45 may interfer with suspension componets. try the wheel calculater on tire rack to get in the ballpark. dont forget you also have to clear the calipers which push the spokes outboard
275/35/18 with the car slammed almost rub just having the car parked.I think I should just call a wheel shop and see what they have tried.
Like you can have 2 same spec wheels with say a 38mm offset and one if them not fitting because it has thicker spokes and they wont clear the brakes.
11 in wide is probably a no go so maybe a 10 in will be okay to stretch a 315 Mickey on it
i dont have a definate answer for you merely some suggestions that may help you without spending big bucks for something that wont fit
I just talked to my friend with the supra and he is running the 315s on a 10in wheel.if I can find a wheel that will clear our brakes and sidewall we will have the ultimate drag setup for our cars.
His supra has sooo much grip with the 315s that it makes my bfgs feel like street tires.here is his car and I spent about 10 minutes checking his wheels out thinking to myself that I think I can get these to fit lol
And the rolling diameter will be 25.5 with the 315 mickeys so it will be STOCK rolling with no issues with traction control
