CEL!!
Any clue what this might be? Vacuum leak maybe? The car has 81k miles, so I went ahead and ordered new plugs. Any help would be great.
Quick question. Did you wash the car or drive in rain before this happened. When I wash my car, it goes haywire now. Some wires or sensors are unhappy and it throws similiar codes. Not sure what is causing it but I have learned to live with shutting the car off when I wash it in touchless wash.
Clear the codes and see if they come back. Of COURSE check those plugs when you pull them and see how they look. Should be fine though. We have lots of stories of pistons going....never 3 in row.
With my luck I'll be the first person to lose 3 pistons at once!
Thanks guys!
hopefully you didnot injest water while driving in the rain, i know it is hight unlikely. do a compression test.
Checked for fault codes. Found misfire codes for all cylinders. Checked actual misfire values while running. All cylinders intermittently misfire. Tested coils and spark plugs. Checked condition of spark plugs. Coils, wires, and spark plugs ok. Spark plugs indicate an extremely rich mixture. Check O2 sensors. O2 sensors before the catalyst (front) malfunctioning. O2 sensors were noted to be installed backwards. Front O2 sensor installed in rear, rear installed in front. Wiring was cut and extended by exhaust installer. Connector ends installed on wrong sensor. Rewired connectors and installed sensors correctly. Pins #1 and #2 switched / crossed on front sensor. Swapped wire #1 and #2. Cleared codes and test drove. Vehicle idles and runs normally now. No misfires detected.
