Airmatic line fix
Old Aug 22, 2011 | 10:32 AM
cwmateiuc's Avatar
2006 E55 AMG
Airmatic line fix
Anyone know the proper way of fixing one of the lines to the air suspension?
It's that hard line, it broke and replacing the entire line would be way too much work, i would rather fix it.
Old Aug 22, 2011 | 02:18 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I hate to say this, but to repair the line correctly, ensuring no further leaks, you might have to replace teh entire line.
Old Aug 22, 2011 | 05:18 PM
Hellzno's Avatar
E55 AMG
i am not sure but is it like a plastic water line to the ice maker on back of refrigerator/freezer? if so then maybe some compression fittings could work. just a suggestion.
Old Aug 22, 2011 | 05:22 PM
Shifter's Avatar
E55, SL63, ML550
MB has a repair kit for this at the dealers
Old Aug 22, 2011 | 09:30 PM
izzyz28's Avatar
2004 E55 AMG
If its just the end, cut it straight and tighten it back into the fitting. Otherwise you'll have to get a compression fitting coupler. The lines hold about 150 PS I.
Old Aug 22, 2011 | 11:47 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Plenty of aftermarket repair kits available for air suspensions though I would visit the MB dealer and get their kit. Not sure of the price though .
Old Aug 26, 2011 | 12:04 AM
cwmateiuc's Avatar
2006 E55 AMG
I'm confused on what you mean by that....How would I just tighten it back to the fitting?
Old Aug 26, 2011 | 09:32 AM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
/\ He's talking about just getting a new ferrell and nut since there is a little bit of play in the line. So cutting it tight against the connection at the strut, and re-do.
Aaron
Old Aug 26, 2011 | 10:22 AM
cwmateiuc's Avatar
2006 E55 AMG
Aaron
Well, it is broken right next to the compressor.... Sorry for being such a noob at this haha... What exactly would I need? I think it literally broke right before the compressor.
Old Aug 26, 2011 | 11:01 AM
grantwoodtx's Avatar
GLE 63S
Pictures would have helped...
Old Aug 26, 2011 | 12:26 PM
cwmateiuc's Avatar
2006 E55 AMG
Well, the car is at a shop right now.. But I should be going there later one, I'll snap a few pictures.
But it's pretty much this.... The compressor with the distribution block attached to it with all of the lines attached except for one where it's broken off, not far at all from the fitting. Can I just cleanly cut it and get a new fitting and attach it?
Old Aug 26, 2011 | 03:05 PM
Yuille36's Avatar
That is what I thought you were going to do, as well as you had enough acces line.
The last thing that you want is, for the the line bind again.
