Which Meth Kit to get??
so Which one should i go for now
AQUA MIST-SNOW PERFORMANCE -COOLING MIST...
many horror stories with the devils own kits from nozzle screens getting sucked into intake, to pump dying during WOT and not pulling timing back fast enough to prevent detonation.
i ran devils own when i was stage 3 as it was cheap and i was only using it for cooling then, but when i went to Tial 605 turbos i went with aquamist as i was then using it to advance timing and wanted the safety of aquamist then...
Kits works based on boost or based on Injector flow (Injector duty cylce). Each type has its own advantages and disadvantages.
Study the systems very well to decided which one to buy. then you move to the next problem, where to place your nozzles? how many? what size?
Just make sure the nozzle is integrated into 90 deg elbow to avoid problems while installing the nozzle, the following link may help you to decide
http://www.alcohol-injection.com/en/...jection-nozzle
Stay away from big size nozzle for our car when used Pre IC or Post IC, stay with medium (above 300 cc to 450 cc, my advise) and when used before SC, use very small one (60 cc (if possible) to 150 cc)
Good luck
Keep in mind i have a meth kit installed and I plan on keeping the Nozzle/lines perhaps solenoid, right the way they sit right now..
http://howertonengineering.net/
