Forgestar --- Ball or Conical Lug Bolts ? Tested factory ball and they seem right
I read that forgestar changed their machining of wheels so that ball seat lug bolts could be used.
I tested one of my stock lug bolts with the wheels off the car and they seem to fit perfect.
Any advice ? How do I figure out what is needed ? I did email forgestar will see what they say.
Thanks!
With stock Ball I got about 4.5 turns. With conical I got close to 7.
I went with 14x1.5 27mm
So, my first thought is run! Find a company with better quality control.
If you already purchased them, inspect them carefully before mounting. As for the bolts, the bolt holes are narrow so conventional wheel locks might not work, ymmv. I went with spline drive conical seat lug bolts that were 25-27mm. 25mm would be the minimum length you could use.
You don't want to run a cone bolt in a ball seat or vice versa.
