Mod Gods showing up for the holiday!
We are even getting some cooler weather to help out. Temps will plummet from 108 deg. to 94 deg. highs!
I did weigh the front rotors and they are 23.5lbs each VS stock 33.xxlbs each.
This will check off two of the 14 Texas mile mods in the works for October!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
If I wasn't tied up this weekend I'd be digging into her. I'll bring the booze.
I love these heads, and look forward to what they can do. Brooke, you are a pioneer, and have some great data to use for comparison. 180.5 is my recollection
No cams for me at this time. Like to do one major mod at a time and test it, when possible. We have to get all this stuff together and still get tuned to make it all work right.
I have a rebuilt bottom end but still used older heads, so really looking forward to fresh race heads now.
I did drive 120 miles each way to my regular dyno last weekend , to get a fresh baseline. Glad I did , as power was down in the 106 deg heat. Will put all this info together after we get parts and tune completed.
www.ultimatepd.com
