Drag radial question??
My last track outing I got whooped by a GT500. He had less whp and torque than me, yet he had massive rear DR. On a day when me and other cars struggle for traction, the GT500 just dead hooked. So why can't we run fatter rear tires on our car?
I looked at Jegs and they have this
http://www.jegs.com/i/Mickey+Thompso...3785R/10002/-1
Looks like the diameter is ok for our car. Will they fit? I'm thinking about getting them and mount on my 18x10 Forgestar rims. Bad idea?
Im trying these toyo tq 275/40/17s out... apparently they hook hard, and their cheap. 550+ whp z06s can launch off them and get 1.5-1.6 consistently. They must make a 18" DR as well...
While the tire can easily be wider than a 265 you must make certain it is not significantly taller than your stock tire. Usually 26 inches is max....
I would stay as close to 26" tall as possible , but yeah a 10" that flexes to 12.5" is gonna launch you harder than a 9" flexing to 10.5 or 11,
..Dont care how good someone can launch their car, if the prep sucks you aint going anywhere. Enough Sidewall and room to squat is key for these cars
That tire is not that tall but you would need to bring the wheel in as fas as you can to make it fit.
You only need to go wider when you're not hooking up anymore no matter what you do.
I honestly think the 265 or 275 drag radials are great. There are some other options that work even better but, for something simple that's all you really need. Adding more tire is not going to make the car leave any harder. Unless, your spinning like crazy out of the hole or when shifting into 2nd. Which I doubt. Good luck!
Go look at a TRUE slick, and you will find that the sidewalls are paper thin, TO allow them to wrinkle. Hence they need an inner tube for support.
THICK sidewalls, or more importanly STIFF sidewalls are for handling. They prevent the tread pattern from rolling over while corning and to try and keep as much contact patch as possiable on the ground.
Edit: a little tire 101
As indicated by their name, drag radials have a radial carcass designed to maximize off-the-line traction by using a soft compound and a reduced tread depth. Unlike slicks, drag radials maintain a stiff sidewall that ensures stability at high speeds, making them the most streetable of the three types of drag tires. While offering superior traction compared to ordinary radials, we’ll focus on slicks as they require a different approach to care and feeding.
There are several D.O.T.-legal slicks available and they all share some common features—a soft compound and a two-ply wrinkle-wall construction, just like their cousin the drag slick. These tires are virtually slicks, but with grooves so they are legal for street use. (That doesn’t mean, however, that they are suitable on rain-slicked streets.)
Drag slicks are racing tires which offer uncompromised traction. As the name implies, slicks have no tread so as to maximize the contact of the tire. Like the D.O.T.-legal slicks, drag slicks feature a soft compound and a soft, two-ply sidewall designed to wrinkle on launch. These tires should never be used on the street. If you were to get caught in the rain or drive through a puddle, they would instantly hydroplane. Also, due to their soft construction, slicks are prone to punctures, and handling is compromised.
As a long time Drag racer I can say that when we ran a class car, we always used the smallest, lightest tire that would get the job done so as to not waste any HP turning the tire instead of moving the car.
When bracket racing, always use the biggest tire that will fit, even if it's too big, to completely eliminate wheel spin and be more consistant.
1.69 sixty seems respectable to me for these cars.
