SBC Brake Diagram…. Disable Question
I assume a simple pad change is quite easy/straightforward. My only concern is: any specific way to put pads back in (I.e. top/bottom/front/back/etc)….. and also: how do the carbon sensors need to be installed?
If one was to keep careful track of the removal of old pads/sensors would the job be pretty straightforward & therefore simple?? Has anyone (who has access to the machine) turned/resurfaced these rotors? I'm not replacing them as they are fine, so better off left alone or not?
Thanks!!
Install is as they say the reverse of removal
http://www.bennetts.com/electronic-d...459-564165.php
You can also deactivate through STAR, and there's always the nuclear option of disconnecting both of the car's batteries. Take your pick of methods; just deactivate the SBC before working on the brakes.
I've attached a .pdf of actions that will activate the SBC.
Thanks!
Mike T.
Yes
No nothing else needs to be opened
