Power loss (s/c works fine) :-/
Old Sep 23, 2011 | 01:20 PM
StabMe's Avatar
MB CLS AMG 55
Hey there guys!
Once again, another power-loss post in this section. But I think this time it is a little bit different than your regular I/c pump sc shutdown :-)
So, I have cls55 2005yr. Suddenly, it began to lose it's power and now even cls500 runs faster than my(ex)beast.
So I checked it with star diagnose. It showed no errors on ECU side.
I took it for a ride. IATs are about 68-70C. Pressure from the s/c is about 1500hPa which is about. Now, is it enough for such a ride?
If the problem is not with the sc making not enough boost, what else could it be?
The blow off valve is fine either.
So I am sitting here and scratching my head.
Any help would be greatly appreciated.
Thanks!
Old Sep 23, 2011 | 02:58 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Not sure about massive power loss but don't ever underestimate the power of a worn belt. I have heard guys claim "night and day" power improvements with just new belt.
Old Sep 23, 2011 | 03:07 PM
StabMe's Avatar
MB CLS AMG 55
Hm... Will check that tomorrow. Is it possible to tighten the old one just to check for improvements?
Old Sep 23, 2011 | 03:12 PM
Jakpro1's Avatar
Oh also try a sneaky ECU reset.
https://mbworld.org/forums/w211-amg/148019-holy-crap-you-guys-sneaky-ecu-reset-works.html
These cars are ALWAYS adapting to your driving. Since we all don't drive on the Nurburgring constantly, it sets you up with granny settings on your tranny.
Worth a shot to cover the basics.
I will let the pros chime in on the big stuff.
Oh and can't tighten the belt. Its on a spring tensioner.
Old Sep 23, 2011 | 11:28 PM
StabMe's Avatar
MB CLS AMG 55
Tried to reset ECU - nah, didn't help.
Old Sep 23, 2011 | 11:43 PM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
Was it a gradual loss of power? If so, you might check exhaust back pressure. It may be a clogged catalytic convertor.
Old Sep 23, 2011 | 11:52 PM
JoshM813's Avatar
2005 E55 AMG
I'm in the same boat but I just got the car a week ago and dynod it today. Came up with 346whp 401wtq. Conditions weren't optimal, they were 90F but I just wanted a rough baseline dyno before I start modding and the operator dyno in 3rd gear in the regular mode. I was incredibly disappointed as I had just swapped the upper tensioner and supercharger belt. I know my H/E pump is going out and I ordered the CM30 and should be here next week but I cant imagine the pump is causing atleast a 40whp loss. Maybe a combination of heat, pump, operator error and 3rd gear created ssuch low numbers but I'm doubtful of it being all of that. I also did one run in an 1/8th mile track and only did 8.6@82 mph (incredibly disappointed by this...I came from a 335i and ran a 7.9@91 on bald tires and just pump gas and usual full bolt ons)
Old Sep 24, 2011 | 12:04 AM
StabMe's Avatar
MB CLS AMG 55
Yes, the power vanished over about 2-3 days gradually. Yesterday we tried to do a run without catalytic convertors - same $$it.
Maybe it is plugs? Or maybe i should clean the injection system?
If only I could check if what supercharger provides is enough of a boost... But no one seems to know.
Old Sep 24, 2011 | 01:02 AM
skratch77's Avatar
2005 E55
You have a dead pump!!! 70c is 158f....way to hot enless it is 135f degrees out side
Old Sep 24, 2011 | 01:21 AM
StabMe's Avatar
MB CLS AMG 55
Hm.... Could be true, yes. It still fell into the normal range so I assumed the pump and IATs are in check. What is the maximum temperature of the IATs, btw, for the s.c. To be working?
Old Sep 24, 2011 | 12:10 PM
Bramage's Avatar
F-250
I think the SC will start shutting down around 170F, but you should see around 20F over ambient driving normally. The problem is that when you get on it, the IAT's go up very fast. 158F sounds like a bad pump, unless it is 135F where you live
Old Apr 12, 2013 | 10:54 AM
KraljAco's Avatar
E55 W211
Change map sensor!
Old Apr 12, 2013 | 11:02 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
Lol great suggestion 1.5 years later
Old Apr 12, 2013 | 11:14 AM
Hulk's Avatar
A Merc
He would get a code for the map sensor
Old Apr 12, 2013 | 12:49 PM
KraljAco's Avatar
E55 W211
Yeah, saw that now.. I'm new member here. Sorry!
Old Aug 9, 2015 | 12:57 PM
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
Originally Posted by StabMe
Hey there guys!
Thanks!
I know it has been years, but I wondered if you ever solved this problem. I am experiencing the same problem and cannot figure it out. The pump was replaced and is working fine and been bled. Now I'm ready to change the SC clutch. Any help is MUCH appreciated.
Old Aug 9, 2015 | 03:57 PM
jcjmw's Avatar
2005 E55 Wagon
Do you know what your IATs are? You can start from the basics... Check/clear cels and check your IATs at end of a WOT run.
Old Aug 10, 2015 | 07:53 AM
TraumaDude's Avatar
Forgive me for my engine ignorance, but could you define: IAT and WOT?
Old Aug 10, 2015 | 08:47 AM
TraumaDude's Avatar
BTW, changed the super charger belt after power reduction, that didn't make any difference.
Also, thought it might help if I posted this...
Attached Thumbnails Power loss (s/c works fine) :-/-dyno.jpg
Old Aug 10, 2015 | 09:23 AM
jcjmw's Avatar
2005 E55 Wagon
Intake air temp and wide open throttle. Log your runs and show your tuner. Also, show your tuner your dyno sheet. Get your tuner to assist you.
