SL55 and CLS55 - same SuperCharger?
It turned out that the problem i've been having is actually low pressure from S/C - only about ~1000hPa which is even less than the reference range (>=1300hPa, according to Star Diagnose).
So... the solution is simple - replace the S/C. the unit itself is very expensive and i found a used one for just about $1300. The problem is - it was installed on SL55 AMG 2004yr. The shop owner says that they are idectical and that i shouldn't worry. Now... i wouldn't worry, but it has a different part number. According to dealer's software, the part number for my suupercharger must be A113 090 02 80. The guy who sells it has an S/C with a P/N A113 080 02 80.
to add to the confusion - according to the dealer's software, both SL and CLS has an S/C with the same P/N - A113 090 02 80.
Any suggestions?
When you said your iats were 68-70c was that driving around? anything over 140F and you car is going to dump fuel and slow you down.
Your temps were 160F and I had those temps with a dead pump at idle and would hit 180F on a blast threw 3rd gear.
your supercharger will read lower boost if you have done exh work,you metioned you took your cats out,that will lower boost pressure.
Edit try this as its the best way to find out if its not your blower.
let car sit over night and in the morning reset the ecu with a scan tool and clear the LTFT long term fuel trims.This will clear the massive fuel your car is dumping becasue of the 70c it saw.
then on a cold car drive it around for 2 min to let it warm up a little and then do a first gear blast and see if it makes a difference.Im willing to bet that it will break the tires loose and after the temps hit 70c again you will be back to where you are now.
If your cooling is working you should see the aits rise and fall quickly down to about 6-10c above the out side temp.
can you also list what mods you have? are you on stock boost? I didnt even hit 160F (70c) the other night going down the 1/4 mile and my aits started at 89F and I peaked at 148
the IATs were in fact very low. I was able to add a LITRE of cooling water to the system. I/C circuit is separated, too. IATs are now in 48-51, no higher.I did a few WOTs but it feels the same.
Now... i did remove the cats but when i saw it didn't change a thing i removed them back. So the pressure today is ~1100 instead of ~1400 it read yesterday. Star says it should be higher than 1300 or equal to.
Now... the supercharger that is currently installed on the car was once removed and repaired because it produced a lot of noise, because of the damaged bearing (maybe i am using wrong word). The guy (a wizzard) who did the repair said that this unit won't be able to produce as much pressure as before. Here are the photos i took:
So... Now, that i ruled all the other possible reasons (even the fuel pressure reads 0.5-0.5 and doesn't drop on WOT), i think i can conclude that it is the S/C.
No?
http://en.wikipedia.org/wiki/Foreign_object_damage
