E63 on the track (TWS)
Old Sep 26, 2011 | 04:25 PM
NorwayStian's Avatar
2012 E63 AMG
http://www.youtube.com/watch?v=Z6pHfQKjEfA GoPro roof mounted. Noisy...
http://www.youtube.com/watch?v=No6KV_AQoMw Inboard cam.
Hope to see some other E63/E55 on the track next time
Stian
Old Sep 26, 2011 | 04:33 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Nicely done man. Looks like a lot of fun. Car sounds good too
Old Sep 26, 2011 | 04:40 PM
02Drunkenup's Avatar
335i
Looked like you had a good time, cool videos
Old Sep 26, 2011 | 04:49 PM
2012 E63 AMG
Was going pretty fast now and then But it doesnt take long before the tires get overheated with this heavy car. Next time Im going to try out some slicks/street slicks...
Old Sep 26, 2011 | 07:18 PM
BenzoBoi's Avatar
Super Moderator
W221
Old Sep 26, 2011 | 07:24 PM
BenzoDoc's Avatar
2015 E63S 4Matic
I responded to your pm. Sorry I couldn't hang out but like I said I had to go do some mangineering to get the race car back on the track as quickly as possible.
Old Sep 26, 2011 | 07:42 PM
Jdub55's Avatar
2004 E55
Very cool. Thanks for sharing
Old Sep 26, 2011 | 08:02 PM
stevieg's Avatar
2007 E63 AMG, 1991 NSX, 2007 Corvette
Norway-Cool video. Seems like the track is suited for the E63. Big sweepers.
You kept a really good line around the track, the opposite goes to the ZR1 driver !!! He broke at every turn !!! Not too often a heavy 4 door can go out and perform like that. If you try a set of Hoosiers, it will be night a day for you on grip.
Atlanta has some great tracks. Road Atlanta, Roebling Road, Barber (
AL). Atlanta Motor Speedway.
It looked like the track was pretty much empty which is nice. But I am sure the heat was a *****.
Old Sep 26, 2011 | 08:20 PM
2012 E63 AMG
Im actually suprised over how this car takes corners, keep in mind the weight of the car and the air suspension! It rools, but it can carry more speed then i thought was possible. But as i meantioned earlier, due to the weight of the car it dosnt take long beoire you overheat your tires. My tires was 95% friday, after 2 days at the track down to 15-20%.
ZR1 took it easy, dont know why. That car is a beast with right driver!
Slicks next time
Old Sep 26, 2011 | 08:31 PM
2012 E63 AMG
I also belive that many of the E63 driver (seen on youtube etc) makes a huge mistake with not having enough right pedal in high speed corners. If you let go on the throttle, in a typical high speed corner, you loose your tail grip...Its a fine balance between understeering & oversteering in highspeed corners on theese cars. (when driving without TC)
Old Sep 26, 2011 | 08:34 PM
Helms's Avatar
C63 AMG
Awesome videos man, thanks for sharing.
Old Sep 26, 2011 | 11:14 PM
e500slr's Avatar
2011 E63, 2013 CLS63
If this car weighed like 1550-1600kg it would be much better on the track especially with the KW Coilovers, the weight hurts it bad. Mercedes could have worked on the handling of this car more, it holds it's end on the street and is pretty stable but on the track the brakes fade, the tires shred from too much heat, too much weight and struggle for grip, the engine in the 55ks gets heat soaked. It's definitely no track car but hey, it was never made as one. Who spends most of their time at the track either?
Old Sep 26, 2011 | 11:21 PM
BenzoDoc's Avatar
2015 E63S 4Matic
Make sure to check the insides of your fronts, I corded my front right tire tonight after just a couple of hot laps in the E55 on Saturday. Outside/middle are totally fine. The same thing happened to our E63...front right inside after just a couple of laps at TWS.
Good to hear that you'll be running track tires next time.
Old Sep 28, 2011 | 02:30 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Very nice, good to these cars on the track.
Old Sep 29, 2011 | 03:40 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Since the Hoosiers are not XL load rated, what concerns are there running them??
Old Sep 29, 2011 | 04:06 AM
iAMGod's Avatar
996tt
Fan Helvete!
Very nice...was this filmed with a gopro?
Old Sep 29, 2011 | 08:37 AM
2012 E63 AMG
Jon207E63P30: I raised the question about the weight of the car. Hoosier forwarded my mail to sportscar performance, (hoosiers dealer in Houston)
Will let you know the answer...
iAMGod: Should be, faen i helvete Inboard cam is not gopro...
Old Sep 29, 2011 | 08:59 AM
2012 E63 AMG
Answer from Hoosier:
No one’s slicks are XL rated.
You’ll just have to adjust your air pressure accordingly. You should be starting your cold pressures at 40 psi
