Launching with Drag Radials
(Loco, scratch and few more lol)Suggestions on best way to launch on DR's?
Burn out, in the water box? Or get tires wet and burn out, outside waterbox?
Duration of burnout?
Launch: Hold brake, and gas to ????RPM, and than just let go brake and mash gas? Either it hooks or it doesn't. (Quoting somebody... lol)
Thanks guys
Thanks guys
Good Luck!
Good Luck!
Dont forget to raise suspension and keep on comfort
Neck brace is mandatory if you follow these steps
Take a look at this launch and notice there's powerbraking
http://www.youtube.com/watch?v=G1Vdr4KAZgE
http://www.youtube.com/watch?v=Gy4eo...76075&index=38
Ignore the crappy burnout as there was only like 2 cups of water in the burnout box and I couldn't get the slippage needed to break the DR's loose (that's how sticky MT's are) but settings are normal ride height, 900 rpm, shock setting on 1. This was shot by some random guy and I found it on YouTube.
The exhaust you hear is from that beast in the left lane. Gotta love AMG a nice quiet 11 sec 1/4
I initially started with 15psi. Tires (275/40/17), and worked it down to 10psi even as per suggestions of some people.
I tried launching from 1000 rpm it made no difference. Maybe I should launch from 2k?
Also these drags are new, somebody was mentioning something about heat cycling? When I was doing burnouts, out of the 4 times only saw smoke once lol wtf
Given my current et, trap, 60foot, with a 1.7 60' what kind of et should one expect?
10 sec pass
Nice pass! I should have experimented with suspension settings but left it in comfort, and raised.
Are 275's drag radials? If so you should have run 20-22 psi and do the burnout in 2nd also I wouldn't launch at anything higher than 900-1000 rpms. Try this take the slack out of the drivetrain and launch off idle. With a 1.7 you should find yourself in the 11.7-11.8 range based on your best et so far
i used to run 26 psi in my 16" d/r's and 36 in my 19" street tires and i don't know of many people that can say they've outperformed those settings.
I will give that a go next. So low psi is wrong? Man these guys driving gt500s, and high hp mustangs were telling me this... lol
i've run with the quickest s600 and sl65 (at the time) and we tried many things and came to this conclusion in spite of what all the "drag racers" were telling us about tire pressure.
lol
pure fluke
ran a 12.5 all stock
