To those who wonder what it would be like to disconnect the bypass...
When I removed my supercharger and reinstalled it for the meth system, I must have forgotten to plug the bypass valve under the supercharger because I immediately get a code saying it's not functioning.
Sooo...I figured that before I fix it, I may as well play with it to see what changes.
Well, to be honest, not a whole lot. The ONLY thing I can feel different is that when I let off the throttle the car takes maybe 1 second to stop accelerating when before it would be instant. This would be because the engine is still presurized for a second or so even after the throttle closes. The bypass valve would vent any pressure left if it was working. It felt kinda scary at first cause I thought the car was not going to stop...lol....but it's more mental than anything else.
Other than that...it'll still kill power just the same due to wheel spin but I have yet to see how it affects boost from gear to gear. Maybe some more logging tomorrow.
Same as with no blower belt, maybe even more wimpy. Neat that your S/C stayed on.
Anyways...here are some logs.
Compared to my previous ones...they seem very similar so I don't really see an advantage to this.
These are the previous ones.
you will need to tune it for this, we faced 2 55k that had them closed, one used CLK DTM S/C or SLR ( S/C part # started with 199 ) the other was already modded by ART and the bybass TB was removed and a plate was installed.
closing it without a tune to fix it will make the car working as your S/C is off.
OETuning Jeremy tuned the cars for these.
