AIT monitor, it works!!
The last couple days I've been testing out my self made in car AIT monitor. With the car always display the outside temp on the cluster so I figure why not there, on the cluster.
A piece of double electrical wire about 8 feet long and 4 electrical splices are all you need.
Get under your car, locate the out side temp sensor (driver fog light area), unplug the sensor (save it somewhere so you can reuse later), use two splices and tap into the sensor harness, run the wire up to the engine bay. Use the other two splices to tap into the AIT sensor (it locate in the y hardpipe). That's it you're done.
Turn on the car and your AIT should display, if you run the wires wrong it should show 185 degree. If that the case just switch the wires.
There are two problems I found so far with this. One, the temp will display in Celcius even though the display say F. Two, you no longer can read the ouside temp. But this can be easily fix. Enjoys!!
On a normal car, AIT always higher than ambient air right? By doing this I'm fooling the ecu to think AIT is as cool as ambient, hence advance timing and add fuel. Wouldn't that means more power?
http://www.e46fanatics.com/forum/sho...d.php?t=817911
This was posted below and seems pretty valid. Not sure what it means in the end though. The car IS dependent on the sensor or not????
Ambient temperature sensor
The ambient temperature sensor is not directly linked to the engine control unit but to the instrument cluster. The value of the ambient temperature is sent to the engine control unit via CAN bus. In the event of a fault, the instrument cluster sends a characteristic value which the DME interprets as a fault.
If a fault is entered, a substitute value is calculated for the ambient temperature from the intake-air temperature. The ambient temperature is required for many functions in the engine control unit that contain temperature-dependent parameters.
