Best Place to Buy a Johnson CM30 Pump?
Old Oct 4, 2011 | 11:28 PM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
My recently acquired SL55 with 15K on the odo suffered from supercharger shutdown no fewer then 4 times on a spirited mountain drive over the weekend so me thinks it's time to pop in a CM30. Especially as the bumper is off the car for some cosmetic mods.
I haven't bought one since my E55 days 4 years ago. The cheapest I have found is $165 which strikes me as higher then I remember.
Sound right?
If not, what's the best place to get one?
Thanks guys!
Old Oct 5, 2011 | 08:23 AM
jmb614's Avatar
E55 AMG
It may cost a little more, but go for the Meziere WP-136. I originally had a CM-30, but quickly moved to a Meziere. Simply my 2 copper.
Old Oct 5, 2011 | 08:48 AM
novae500's Avatar
W211
Bosch came out with a revised pump and several members have bought it with no issues.
Old Oct 5, 2011 | 10:54 AM
Thanks for the replies. I like the CM30 as it can be used in the same bracket and location as stock (just wrap a rubber insulator around it), is quiet, and has worked flawlessly for me in the past. If I was doing an auxiliary tank, I would use the Meziere WP-136 without question.
I finally found where I used to order them from after an hour of digging:
http://apeusa.com/html/jabsco.html
They are $145 delivered for a 12V CM30 w/20MM ports in case anyone else needs one from a great supplier (I order race car fuel pumps from these guys). That beats everyone else I'm aware of by at least $20.
Old Oct 5, 2011 | 07:13 PM
chawkins2001's Avatar
2006 E55 AMG
Meziere all the way, it is a beast of a pump, dont forget the two barb fittings needed to bolt right into the E55 plumbing
Old Oct 5, 2011 | 07:23 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
The new BOSCH is the best.
Old Oct 5, 2011 | 07:32 PM
This is going to get interesting!
Old Oct 5, 2011 | 10:57 PM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
I just installed the new Bosch pump. Very simple plug and play. I found a few available like this one:
http://www.carpartsdiscount.com/auto...ml?3593=266876
