530whp club
Old Oct 6, 2011 | 02:04 PM
skratch77's Avatar
2005 E55
530whp club
Got the car on the dyno today to see what she did as last time i was pig rich up top end.My plugs were all lose and after I tightened them up the car felt alot better on the street.
Ill post up the video later and sheets.It made 530whp at 6300 and we let off and you know how these cars keep going for a second after wot and it lost a little by 6500 rpms.
Pull was done in 4th and a/f up top is perfect!!!
Old Oct 6, 2011 | 02:13 PM
jcjmw's Avatar
2005 E55 Wagon
Nice!!!
Yeh, post the dyno sheet. I am curious to see your AF ratio line in context of your HP and TQ line.
Also, I thought I read a thread that you sold your car? Or, was that some joke?
Old Oct 6, 2011 | 02:18 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Nice and cool up your way now right, what was it like high 50s?
I am also so confused with this is the car being sold or kept stuff since you keep going to the track, doing dynos, look at buying more parts.
Old Oct 6, 2011 | 02:23 PM
tbal's Avatar
Haters crazy
Dyno sheet? Would love to see them afr's
Old Oct 6, 2011 | 02:33 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Old Oct 6, 2011 | 02:37 PM
tbal's Avatar
Haters crazy
Scratch I thought the car was sold? lol
Old Oct 6, 2011 | 02:44 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Sold...not sold. I can't take the mind games!!!!!
Old Oct 6, 2011 | 02:48 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Well done!!!!!!!!!!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 6, 2011 | 03:10 PM
skratch77's Avatar
2005 E55
I find out today about the sale.I accepted the offer and now its on the buyer.He came with a 28k check in my name and I told him I wanted 30 firm.
he agreed to give me 29,300 and pay off the labor I owe for the tb and some parts that just got installed.
Old Oct 6, 2011 | 03:21 PM
BenzoBoi's Avatar
Super Moderator
W221
Sick numbers my friend! Can't wait to see/hear about a new PB!
Old Oct 6, 2011 | 03:29 PM
skratch77's Avatar
2005 E55
Old Oct 6, 2011 | 03:33 PM
AKnight55's Avatar
why did the torque go down from 600 last dyno to 575 this dyno??
Old Oct 6, 2011 | 03:38 PM
skratch77's Avatar
2005 E55
started the pull around 3300 after peak torque
Old Oct 6, 2011 | 03:42 PM
Jakpro1's Avatar
Looks good to me bro!
Nice!
Old Oct 6, 2011 | 03:49 PM
skratch77's Avatar
2005 E55
Nice!
Thanks!!! 4th gear too
Old Oct 6, 2011 | 03:55 PM
skratch77's Avatar
2005 E55
http://www.youtube.com/watch?v=WwWyHTPeqjk
Old Oct 6, 2011 | 03:59 PM
skratch77's Avatar
2005 E55
Originally Posted by Exotic-metal55
Well done!!!!!!!!!!
Thanks bro,you have no idea how tempted I was to buy that 185 pulley of yours.I would of killed 550whp with it for sure
Old Oct 6, 2011 | 04:19 PM
AWOL's Avatar
e55
nice
Old Oct 6, 2011 | 04:24 PM
KLR CLS's Avatar
CLS63 PP
Welcome to the club...
Old Oct 6, 2011 | 04:31 PM
V12Godspeed's Avatar
Your worst nightmare...
Very nice healthy numbers.
Old Oct 6, 2011 | 05:50 PM
urbamworm's Avatar
What was the weather? Best part of that dyno is the correction factor (Uncorrected).
Old Oct 6, 2011 | 05:59 PM
skratch77's Avatar
2005 E55
about time someone noticed that this was a raw pull of what my car really puts down with no correction factors inflating the numbers lol.
Temp was 68 in the shop and as you can see 1.0 CF was used
Multiply it by 1.02 for std numbers
Old Oct 6, 2011 | 06:13 PM
GT-ER's Avatar
2005 E55 AMG
Careful with the sheet being uncorrected, STD won't ALWAYS be 1.02 so don't assume so...with such low humidity and temps you could "LOSE" an easy 25whp once corrected to SAE or or 15whp if corrected to STD since the correction factors will probably be in the .95 range when corrected. I could be wrong, but I've seen it before many times with those temps and humidity. Regardless, the numbers are great.
Kinda makes me want to take a shot at the dyno again after discovering a completely loose intercooler to surge tank coupler ( I forgot to even put the worm gear clamp on )...ouch!
If you can tell me the altitude of that dyno I can calculate the correction factor.
Old Oct 6, 2011 | 06:14 PM
BRABUS786's Avatar
Stage 3 63
well done
Old Oct 6, 2011 | 06:25 PM
skratch77's Avatar
2005 E55
Originally Posted by GT-ER
Careful with the sheet being uncorrected, STD won't ALWAYS be 1.02...with such low humidity and temps you could "LOSE" an easy 25whp once corrected to SAE or or 15whp if corrected to STD since the correction factors will probably be in the .95 range when corrected. I could be wrong, but I've seen it before many times with those temps and humidity. Regardless, the numbers are great.
I think we should all dyno our cars with 1.0 CF,my last pulls used 1.02 and 1.03 CF so if we used 1.03 the car would of made 546hp and the only difference was about 8-9 degrees ambient temps,in the real world my car would of made the same power giving the temps only 8-9d higher.
This was also 4th gear and it was heat soaking the blower as well.
The car picked up 7mph in traps just from tightening up the plugs and Im going back to stock plugs.The kid at the dyno said if you are not pinging you will lose power with a step colder plug.
I have no idea of the altitude but I think he said sae would of been .99 and what the car did uncorrected is what its making that day in real life and also said prolly about 10-15 more with colder air hitting the car at 170mph in 4th gear.
for instance I could of gone to the dyno on an 80 degree day and had the car cold and did this same exact pull,in real life my car with a cold engine and blower will make the same power going from 68 out to 78 out but using the CF it would inflate the numbers higher than they really are becasue its over 75 and sae is set for 75 degres ect.
