first mod
Old Oct 10, 2011 | 08:58 AM
keynote22's Avatar
first mod
I've read quite a few threads that say that long tubes should be the first mod someone does. Long tubes pulleys and upgraded cooling and an ecu tune seem to be what people do. I figured an lsd would be my first mod. Why don't more high horsepower cars list the lsd in there mods list? This car can shred the tires in its stock form.
Old Oct 10, 2011 | 09:05 AM
GT-ER's Avatar
2005 E55 AMG
It'll shred them with an LSD as well. Traction control is good enough for me not to care much about an LSD.
Old Oct 10, 2011 | 09:27 AM
Helli217's Avatar
05 E55
Yeah-I'm grabbing second gear rubber on my low mileage stock (other than bosch upgraded ic pump) e55 with newer Nitto NT555R's. First gear is atrocious. I don't see an LSD getting rid of that problem. Need wheels and more patch asap.
OP-After alot of reading/searching, I think I am going to go headers (probably shorties, just my preference, had problems before with longtubes with NY emissions) a tune, and a new H/E, not sure which yet. There is power to be had without a pulley, and you're cooling is already a concern stock, let alone on a pullied beasty. If you haven't already, address your stock ic pump. I bought my car 3 weeks ago and thought it was running strong. I then installed the latest revision bosch pump (113.00 online) and it was a world of difference.
Old Oct 10, 2011 | 10:11 AM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
First mod should be Larger Heat Exchanger and pump.
Old Oct 10, 2011 | 10:54 AM
keynote22's Avatar
Correct me if I'm wrong but my understanding of an lsd is that if one wheel starts to spin the lsd transfers power to the other wheel effectively doubling ones contact patch? The only reason rwe wouldn't want solid axels is because going around corners is a good thing to be able to do. The lsd is a happy middle between locked and open.
The factory system uses the brakes and engine kill to control wheel spin.. generally not a good thing for forward movememt. my understanding of this cars systems must be way off because putting an lsd in my truck made the difference between spinning the drive wheel all the time and using both rear wheels to move forward
Old Oct 10, 2011 | 11:58 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
It all depends on what your plans for the car are and your budget?
Old Oct 10, 2011 | 12:07 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I have been preaching Long Tubes FIRST for mods but now have come to realize they come with a price.
Gotta have tune as you are hacking some O2s off to install. So tune will have to be included in price. Then there are emissions problems. Some long tube guys have problems passing emissions with O2 issues.
Not sure how they get around it. I use a separate ECU that I plug in with my Kleemann tune and it works perfect. That is serious $$$$ though. I had that back in the early tuning days.
Otherwise, be interested how some of the other long tubers are doing it.
Old Oct 10, 2011 | 12:13 PM
If they install the correct parts they will not have to hack up the primary O2's and yes headers should be the 1st mod. You add good hp without any extra heat and your SC runs with less boost. To take full advantage of headers you will or atleast you should get it tuned. Hell you may be able to pick up 60+ rwhp with headers & a tune and call it a day
