Per my UPS scale that is, maybe a tad less on the E class. Nice to have new rotors and loose some heavy rotational weight!
Nice! And at the wheels too! I am also hoping to get a set of the lightweight rotors.
They sure help make up for the extra weight of the trunk tank.
Quote:
Are they the evosport one or another brand ?Originally Posted by Exotic-metal55
Per my UPS scale that is, maybe a tad less on the E class. Nice to have new rotors and loose some heavy rotational weight!(...)
Tell us more.....
- What brand and where did you get them, cost
- Did you need to make any mods to get them to fit
- Weight Front and Back, Stock vs New
Moderator Alumni
dannnggg 50 lbs?!?!
ExploreSuper Member
I wanna know what company too! Those look nice!
Is the weight removed from the "hat" of the rotor or from thinner walls/vanes in the rotors?
Afrer some Forgestars you'll be money
Quote:
These are not Evosports. I bought a set of evos but they would not fit my CL, so I contacted Brad and Evosport to sell me the hats for the Texas mile. He acted like he would work with me but then never heard back or answered my emails. I then was contacted by another company and they sent me these samples! I hope when I give them the good feedback, they will load thier dealers up. Originally Posted by timeToy
They fit right on and it was an easy change out. Just hard getting stock rotors off, as they were rusted on. My front rotors were 38lbs each and these were 22.75lbs each. I have to check on the rears again but most the weight came off the front`s and 20 off the back, as I recall. It may be a little over 50 but again, have to check the backs again. Originally Posted by 1995E320Cab
Tell us more..... - What brand and where did you get them, cost
Quote:
All the weight was in the hats, that I could tell but hard to say.Originally Posted by BBBSS
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
who all are ready to get a set of these hats for the W211 E55?
Quote:
Just hats and no rotors?Originally Posted by shardul
Ok, Brad has sinced contacted me and they just were not able to get the new CL/S class rotors completed in time for the mile. This was a new item for the CL and I think they still stock thier normal rotor packages.
The CL/S class cars share the same rotor size as the E but the hat offset is different. The CL seems to have a heavier steel stock hat. At least from what I have seen posted. Either way, the savings is huge! The rear hats save more than I originally thought, as they are larger than the front hats, as they house the parking brake!
shardul
close
- Join DateMay 2008
- LocationHouston
Quote:
i am sure we can source rotors rings for a decent price.Originally Posted by Hammer Down
how about going to a larger rotor ring? like the 390mm on the 030 CLS? from what i understand, the calipers are the same, the mounting bracket is just different. i'm sure some kind of a spacer can be made in order to fit a larger rotor...
Quote:
I want hat and rotors, for front and back wheels...if the price is right.Originally Posted by shardul
shardul
close
- Join DateMay 2008
- LocationHouston
what would be a good price just for the fronts?
this will be a group effeort so can someone help sourcing 360mm rings with a 10 hole fixture
are OEM rotors truly 360mm? brembo makes a 355mm rotor, but it's 32mm thick... i think OEM is 34mm thick?
those can be had for $220 each...
http://www.racingbrake.com/355x32mm_p/14041-311k-01.htm
shardul
close
- Join DateMay 2008
- LocationHouston
yes truely 360mm and thickness is 36mm and minimum thickness is 34mm
To the post way up there: On most aftermarket 2-piece rotors, the front rotors are a mil or 2 thinner and the vaning wider. The OEM 2-piece fronts are actually beastly pieces that are super tough and pretty thick...
Nice on the 50lbs...That's pretty awesome coming off of unsprung weight...
Don`t remember what the rear weigh but if you know what your stockers are, these rears are 13.5lbs.
