Going TWINCHARGED for the new build!
#76
Administrator
I would hope that now that Brooke and Shardul are sponsors they would do everything they can to win back the trust of members.........we will see.
#81
Not so! If a member has a bad experience with one of our sponsor's they are more than welcome to post their thoughts. I know you have expressed your issues with this group many times without censorship.........right?
#82
Brooke, come out from under your rock, another Red Spoof Racing Pulley fell off, this time a 180mm.
What do you say about that,what is the excuse this time? Just shows you the mentality of this sponsor, he forms a company, makes a pulley, customers by the pulley, they cause damage, he refers to them as kindergardeners and to just ignore them.
NOW THAT FOLKS IS A STANDUP GUY that exudes customer service, CLOWN.
#83
PLATINUM SPONSOR
I am intrigued by the dyno and track results of the synergistic relationship between the two power adders. Blower would turn much slower than stock, as it would be underdriven. Right now , I am contemplating sending the car to speedriven as they also share in the Texas mile goals and have immense AMG Turbo set up knowledge.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#85
PLATINUM SPONSOR
Steve, you are and your band of calumnies , led by your leader Chawkins are thread jumping and highly distorting this thread and many others. Go start a new thread if you wish to continue your misinformation on the web , personal attacks and deframation.
__________________
www.ultimatepd.com
www.ultimatepd.com
#86
Dirt Scooters
FYI Its defamation and there's no "attack" by the way. Its called showing people what you really are. Kinda like why you want to talk about new ideas and BS yet refuse to try and help make the red tooth racing pulley problem go away by doing whats right. Instead of doing the stand up thing and recall them/stop selling them you were money hungry causing more people to tear up their engines.
#88
I am just investigating stand alone, more for saftey reasons than must do.
I have made good progress on my motor build, so if they can fix block and make pistons quick, I will be back racing soon. Putting engine back in and then get everything running great! Then work on turbo set up..
Was the block successfully sleeved?
#89
Dirt Scooters
Was the block successfully sleeved?[/quote]
I'll answer this for you Darton is very close on the sleeves. Should know something very soon like within the next 2 weeks. Seems thats always the story with them also. 2 more weeks every 2 weeks i call. He said the sleeve design is done and now just waiting for the machine time.
