Has anyone had issues with the sun visor?
Has anyone else had a similar issue and is there a cheaper solution?
"When you're on mbworld you should keep all your little questions in one thread instead of starting a new one every time."
True story
It is not 100% stock feel but works way better and it doesn't droop.
thanks for the detailed explanation. have the same problem here (and on the old w210 wagon). I'd think a silicone lube < insert sex joke here > is better than WD40?
Silicone lubricant might also work. The pot-metal barrel contact surfaces are the problems. Might be a question of whether WD-40 or silicone is more durable. I'm about to try WD-40 on the sliding rod of the driver-side visor of my CL55 AMG. I don't want to pay $270 twice!
To forestall problems with the sliding rod, a dry lubricant on the chrome slide might be a good preventative of future problems.
Thanks for the advice! And happy motoring.
Once you remove the visor, hold it with the metal hinge part upward, and just spray a little wd40 around the exposed metal. Then just grab the hinge and swing it as it where installed in the car, after a few times you'll notice it will move lot easier. If necessary repeat. You don't have to stick the plastic straw in a hole?
Re-install it and call it a day
GL
