E55/W211 Front Seat Bottom Removal??
Rubbing my finger over it, there's definitely some "spring" out of place and over time (years?) I'm sure it'll wear through the leather.
So, how can I remove this seat cover and see WTF is out of place? I can do a DIY tomorrow if you guys give me a rough idea of what to expect. I haven't taken a look yet.
I don't want the classic "spring sticking out the mattress" happening in my E55. lol.
Unfortunately it's been pouring all day today so I wasn't able to do much. I did start to take it apart though (sort of) inside the car.
I removed the two E-Torx (short fat silver screws) under the seat that hold the cushion onto the bar on the bottom of the frame. Then I removed the two small black torx on the side of the storage compartment to remove the side covers of it.
Then I removed the 4 e-torx on frame rails on to detach the seat from the car floor.
My questions: How the fu**ck do I remove the black storage box? Mine looks like it has 3 rivets holding it in along the top, and 2 underneath.
I'm 95% the seat has been removed once already, because some of the plastic trim which covers the ends of the seat rails are broken/cracked.
Any idea what might be poking into my leather? If you can provide a pic that would be fantastic!!
Long story short, i was able to push it back towards the seat back so that it lays flat along the length of the seat bottom, rather than close to the seat lip (and thus giving me that pressure against the leather as the leather wrapped down and around the front lip of the seat bottom).
Those pics are pretty awesome though, and I'm sure tons of people will reference them somehow.
What did you do to reattach the storage box to the seat bottom? Did you re-rivet it? Or something else...
Thanks again!
I've got a seat "wobble" that I could use some help with!!
I noticed whenever my brother gets into the pass. seat, the backrest gives a bit too much for my liking, so I had to investigate...
When I grab the seat by the headrest and shake it back and forth, the seat back certainly seems a bit more loose than it should, with an almost side to side rocking present (side to side laterally, not towards the front/rear of the car).
It's definitely not the 4 big torx on the seat rails on the bottom. And somebody has taken this seat apart once before (in my opinion) by the presence of cracked/broken seat rail covers...
So what should I look towards? Or is this slop/play normal???
Sorry to quote all these pics, but....Do you think the fans can be swapped out through the cushion? If not, how would you go about it?
Also, any chance you can measure the bottom fans?
Thanks!
