How can I check the car's oil level?
Old Nov 16, 2011 | 04:37 AM
CityOfAngels's Avatar
2006 E55 AMG
I'm trying to check the oil level via the display in the instrument cluster.
When I have the car on, it says oil level can only be checked with the car off, but when I have the car off, it says car has to be on. What am I missing here?
Old Nov 16, 2011 | 07:16 AM
grantwoodtx's Avatar
GLE 63S
Oil Level
Use the dipstick, you know where it is right?
When you say on or off do you mean the motor is running or not? if that is the case it should not be running.
Old Nov 16, 2011 | 07:54 AM
hyperion667's Avatar
2012 CLS63
yes, dipstick! DUH, LOL
Old Nov 16, 2011 | 10:02 AM
tcoleman's Avatar
2003 E55 AMG
I turn key to position 2 (not cranking engine) and check it before I drive. Works for me...
Old Nov 16, 2011 | 10:19 AM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
the motor has to be off, and cool before the oil can be checked. turn the ignition on. the mph or temp should be on the cluster. toggle down using the buttons on the left side of the steering wheel.
Old Nov 16, 2011 | 12:00 PM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Nickel you are correct. Just follow these instructions and you will be fine. My car does not come with a dipstick. You can only check through the instrument cluster.
Old Nov 16, 2011 | 04:14 PM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
I find it interesting. On my 996, the engine has to be running and the oil warm. Different strokes.
Old Nov 16, 2011 | 08:50 PM
Johncy2000's Avatar
Weird how different German cars can be from each other.
Old Nov 16, 2011 | 10:02 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Almost certain your 996 features a dry sump lubrication circuit. ;)
http://www.youtube.com/watch?v=Ne1qX...eature=related
Old Nov 16, 2011 | 10:20 PM
nicco's Avatar
E55 AMG
You can check it in dyno mode also. But if your sensor is malfunctioning you end up putting to much oil into the car.
