I can finallllllly seeee!
Old 12-05-2011, 11:48 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
So have you guys ever wondered why our bi-xenon don't have great output as BMW/Lexus/Audi. Well I did you guys a favor and did a little work on my headlights. Buddy of mine, Rich from HID Illusionz, finally decided I am tired of the crappy lighting. I really couldn't see past 10-15 away from my car. Did a little research that our E55 Hella projectors probably have the worst lens cause they are "frosty" not clear. Painted the housing a gunmetal/titanium color because my new look for spring is silver/gunmetal accents. Let the pictures do the talking!
10ft away.
23ft away
Old 12-06-2011, 12:06 AM
desired_speeds's Avatar
2007 SL55 AMG
Im actually just about to put a pair of clear lens into a set of W211 bixenons for someone. I have the headlights and lens just sitting here in front of me. The owner of the car was also complaining that the output on the stock headlights suck so I recommended him to do this upgrade.
Old 12-06-2011, 12:10 AM
djrabbi's Avatar
mine have the ZWK lens with purple hue...hopefully maybe this weekend is warm!
Old 12-06-2011, 12:25 AM
2007 SL55 AMG
I ended up getting the standard ZKW-R lens without the purple
Old 12-06-2011, 05:10 AM
edmond1129's Avatar
E55
Very nice....!!! So where did you guys get the lens? And is it coming with just the lens and you need to take the whole light apart and change the lens? Thanks
Old 12-06-2011, 05:22 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
You can get the lens on eBay and for the money I would get the zkw replica's because the cut off is almost identical.
Old 12-06-2011, 07:10 AM
djrabbi's Avatar
Yeah replicas are the way to go! You would need to take the headlight apart to do so. PM me if you want to get it done. Mine was $250 painted/lens swap.
Old 12-06-2011, 05:13 PM
TonyC's Avatar
e63 p30 estate
I have both the OE and AL Bosch (audi) bi-xenon lens in my hands waiting for a headlight tear down. Should I go with the AL Bosch (even though the mounting is off by a couple of holes)?
Old 12-06-2011, 06:14 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
great carpet
Old 12-06-2011, 06:25 PM
djrabbi's Avatar
Get replicas all OEM have frosty. Only acuras and Lexus have clear
Old 12-06-2011, 06:57 PM
Bramage's Avatar
F-250
I have not disassembled one of these headlamps yet, so I have two questions:
What does this do to auto leveling / active headlights (turning feature)? I assume the entire projector housing moves, which would allow the swap without losing functionality. can you confirm?
In terms of installation, is it a direct swap, or does the housing need to be modified?
Thanks!!
Old 12-06-2011, 08:29 PM
djrabbi's Avatar
Auto leveling is a seperate motor so nothing to do with the projector itself. It is direct swap.
Old 12-06-2011, 09:43 PM
AMGPilot's Avatar
2004 E55
Hold on, what are we replacing? where do we get it? and how do we do it?
Old 12-06-2011, 10:06 PM
djrabbi's Avatar
You are ONLY replacing the LENS to the projector, not the complete projector. You can PM me on the info. For $250 for a lot better lighting. I think it is well worth it.
Old 12-07-2011, 08:53 AM
djrabbi's Avatar
https://mbworld.org/forums/mobile-el...ml#post4950024
Old 12-07-2011, 01:41 PM
komp55's Avatar
ML550
Originally Posted by AMGPilot
where do we get it?
From what I understand, you'll replacing the lenses only on your projectors. Here's a link to a source for the replacement lenses:
http://www.theretrofitsource.com/pro...roducts_id=136
Old 12-07-2011, 01:47 PM
djrabbi's Avatar
Yup that's it, but not simple swap. Need to put them in the oven and all that jazz. I let a professional do it instead.
Old 12-07-2011, 02:38 PM
TonyC's Avatar
e63 p30 estate
Detailed bi-xenon lens retrofit install instructions. In this case, it's for the AL Bosch (Audi).
thanks for the ZKW link, komp55
Old 12-07-2011, 02:40 PM
djrabbi's Avatar
if your doing bi-xenon....I think you can just buy ebay headlights and swap the lens out....call it a day
Old 12-07-2011, 03:16 PM
AMGPilot's Avatar
2004 E55
By the time you've removed the headlights opening the housing is the simple part.
Komp55 I found the same source last night, I'll order up the lenses and save $210 and do it myself
Old 12-07-2011, 03:17 PM
djrabbi's Avatar
Good luck!
Old 12-08-2011, 10:35 AM
bobgodd's Avatar
2004 E55
Would anybody attempting this be able to do a side by side of the two light beams? Like say, do the drivers side first, (leaving the passenger headlight in the car) and then turn the lights on to see if the difference is visible?
I'll definitely do this when I attempt this project, but it would be nice to know how much of an improvement there is; to know if it's worth it or not.
Old 12-08-2011, 10:37 AM
djrabbi's Avatar
I am going to have before after pics hopefully this weekend so everyone can see....
I am going to take before pics with both headlights against same wall and do same with new headlights. i will cover up each light so you see the "bigger" picture
Old 12-08-2011, 11:52 AM
djrabbi's Avatar
If anyone wants to do this without waiting. I have a extra set of headlights I can send first with modifications, as long you send yours back. I think this would help out A LOT of people.
Edit: If the the group buy is a success, he is dropping the price a lot!
Old 12-08-2011, 11:54 AM
djrabbi's Avatar
His price is only $100 if you just want to do lens swap, it was 250 for me because I had mine painted.
Quick Reply: I can finallllllly seeee!
